Crank Position Sensor
Old Sep 2, 2014 | 08:56 PM
cw40342's Avatar
cw40342
I have my MINI in front end service mode to change my supercharger oil and install the kit from imperial MINI. While I have everything apart my crank position sensor o ring is leaking is there a special kind of o ring to get or will any kind work?
Old Sep 2, 2014 | 09:08 PM
Eric_Rowland's Avatar
Eric_Rowland
I'd go OEM if you've got that option, as it's just a few bucks. If time/distance doesn't allow, I suppose any 'engine duty' o-ring would work in a pinch.
It's not a huge deal to do it again, but if a sub-par ring blew out, it might make a mess.
Old Sep 2, 2014 | 10:17 PM
elchilo4ever's Avatar
elchilo4ever
I Buy My O-Ring From Here.
http://www.waymotorworks.com/camshaf...or-o-ring.html
Old Sep 3, 2014 | 08:02 AM
jamez's Avatar
jamez
Yup, zip over to the dealer and get it OEM (call first to check stock)
Originally Posted by cw40342
...and install the kit from imperial MINI.
Hey good for you. What serial number are they up to now? I have #17 (but not using it on this current engine build yet)
Old Sep 3, 2014 | 08:50 AM
cw40342's Avatar
cw40342
Well turns out I can get the O-ring from the dealer sweet!
Old Sep 3, 2014 | 09:13 AM
nkfry's Avatar
nkfry
Don't waste your money on a new o-ring, clean up the sensor and mating surface and lay a bead of RTV around the base of the sensor where it mates to the block. Leak permanently fixed.
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 3, 2014 | 09:46 AM
cw40342's Avatar
cw40342
Originally Posted by nkfry
Don't waste your money on a new o-ring, clean up the sensor and mating surface and lay a bead of RTV around the base of the sensor where it mates to the block. Leak permanently fixed. Nick Detroit Tuned
It's actually funny you mention that I was planning to do that anyways. Which color gasket maker should I use?
Old Sep 3, 2014 | 09:48 AM
nkfry's Avatar
nkfry
Black RTV is what we use.
Phone:586-792-6464
Old Sep 3, 2014 | 03:35 PM
cw40342's Avatar
cw40342
black rtv is what we use.
got it! 👍
cw40342's Avatar
cw40342
Originally Posted by jamez
Yup, zip over to the dealer and get it OEM (call first to check stock) Hey good for you. What serial number are they up to now? I have #17 (but not using it on this current engine build yet)
I'm #28 😃
BernieCoop
Sep 10, 2021 03:15 AM
larryd96
11
Sep 8, 2015 05:01 AM
renchjeep
Sep 6, 2015 01:54 PM
jesterofatlas
Sep 4, 2015 11:23 PM
M7Speed
Sep 3, 2015 07:48 AM
