R58 Coupe Spoiler .............
Old Aug 27, 2014 | 07:44 PM
dube53's Avatar
dube53
We all know this feature is nice and distinctive but my car has less than 400 miles and the hatch stamping seems too soft to handle the download of the spoiler in full open position..... no contact with the body panel. Again, the car is new.
It seems there is not enough bracing to support the weight and operating hardware of this feature and there is some stress showing through the hatch body panel. Is it what I have to expect?
Old Aug 27, 2014 | 08:45 PM
NewCooperFanatic's Avatar
NewCooperFanatic
Picture?
I don't follow?
Old Aug 28, 2014 | 12:42 PM
KilmerPT's Avatar
KilmerPT
Neither do I, pic will definitely help
Old Aug 29, 2014 | 05:58 PM
dube53's Avatar
dube53
Originally Posted by NewCooperFanatic
Picture?
I don't follow?
Today, I took pictures but both dents are not easy to see because of the light reflexion. Anyway, I will post some pictures when I will have time.
To figure out the problem, stand behind the car and look at both rear tips of the spoiler. The dents are at 10.00 and 2.00 and highly visible on a metallic paint as mine and clearly visible. You will observe the sheet metal on the hatch is slightly bent downwards the size of a half dollar. This is not a body panel stamping issue.
Old Aug 30, 2014 | 11:53 AM
kg4fxg's Avatar
kg4fxg
Spoiler....
Odd,
I have just a little over 10K on my Coupe which is a 2013 and no issues. Will take a closer look. Just washed today and when I pull it in the garage I always extend the spoiler to dry it off.
Maybe a fatigue metal failure for speeds over 120 mph? Just kidding
Old Jul 11, 2015 | 06:32 PM
483 of 500's Avatar
483 of 500
I just bought my 2014 Coupe. Is there a way to turn off the spoiler so it stays down all the time? I can see an advantage to keeping it down in freezing rain, etc.
Old Jul 11, 2015 | 07:13 PM
Grumpy_i_m's Avatar
Grumpy_i_m
If you have the latest software update in your 2014 coupe, you can use the overhead switch to manually put the spoiler in the up position and it will remain up until you manually use the switch to lower the spoiler. If you were to disable the spoiler so it remains in the down position, the computer will force Dynamic Stability Control (DSC) on at speeds above 50 mph. (Thank you Drivehard)
I am sure there is a software patch that will disable the Spoiler as it is done when the optional fixed mounted spoiler is installed.
I have not had any issues with the spoiler at all , including operation in freezing rain or snow.
Keep motoring !
Old Jul 12, 2015 | 04:54 AM
Drivehard's Avatar
Drivehard
No not really. You can leave it up all the time no matter what speed but if down it will want to come up at 50. The rear active spoiler is part of the designed aero and necessary downforce built into the car. And what was posted is incorrect. If malfunctioned or disconnected you can still drive over 50 but doc will be forced on. U will get a warning on the dash
Just a FYI. If it were to freeze down it will sense the resistance and stop trying. U can still get home. And on my 2013 last winter ( I have a 2015 r58 now ) in NY it was brutally cold and below freezing a lot and it never Froze to the car
See attached owners manual instructions
Sent from my iPad using NAMotoring
Old Jul 14, 2015 | 05:50 AM
+1 drivehard.
OutMotoring
Nov 16, 2015 07:04 AM
jeri534
Nov 6, 2015 01:40 PM
Oct 1, 2015 12:13 PM
Sep 29, 2015 12:17 PM
