Help with rim issue :l
Old Aug 18, 2014 | 08:34 PM
CrossFury's Avatar
CrossFury
I apologize in advanced for asking this but I did not see a sticky on the forum and I cannot find a answer online. I have a 2006 mini cooper s. I also have a set of universal 4 lug wheels 4x100, 4x114.3 just like these in 17x7 http://www.wheelfire.com/scontent/Wh...431-3&SKU=5678. My understanding is that these will fit my mini cooper. My problem is that the lug stud bolt will not even fit into these rims. I am unsure what I need....If someone could please point me in the right direction that would be great! Again I am sure this has been asked time and time again. I just need to know what I have to do.
Old Aug 18, 2014 | 10:09 PM
Alexalvarez's Avatar
Alexalvarez
Are the rims hubcentric?
Old Aug 19, 2014 | 04:48 AM
JABowders's Avatar
JABowders
Veteran: Army
OK, asking for a little clarification.
Is it: The lug stud bolt will not pass through the holes in the wheel, or is it that it does not reach through long enough to seat into the wheel hub.
If it is the bolt will not pass through the holes in the wheel, the possibilities are to replace the lug stud bolts with wheel studs and nuts, there are several available different widths and lengths. e.g., http://www.ecstuning.com/Search/Site...tud/ES2631414/ the trick here is to make sure you get the ones small enough to fit in the size of the holes on the wheel. (don't forget the lug nuts)
The other option is enlarging the holes in your wheels to a size that allows the stock lug stud bolts to pass through.
Best of luck.
Motor on!
Old Aug 19, 2014 | 05:15 AM
myles2go's Avatar
myles2go
You have 14mm lug bolts. Mini switched in late '06 from the 12mm lugs they had been using. Either open up the holes in the wheels or buy a conversion stud kit to go to 12mm threads.
Old Aug 19, 2014 | 10:40 AM
CrossFury's Avatar
CrossFury
The top of my minis lug bolt, the cone I think its called, will not fit down inside the lug hole of my rims making the threads barely stick out on the back. :> Thanks for the help so far guys.
Old Aug 19, 2014 | 11:02 AM
myles2go's Avatar
myles2go
You'll need tuner lug bolts, if available. They have a smaller head diameter.
Old Aug 19, 2014 | 02:32 PM
Thanks for the mention:
12x1.5x60mm for R50 R52 R53 up to 7/2006
http://www.ecstuning.com/Search/SiteSearch/ES2631414/
Nuts are here: 12x1.5 Wheel Nut -7/2006
http://www.ecstuning.com/Search/SiteSearch/ES205/
So check your production.
Old Aug 19, 2014 | 04:24 PM
CrossFury's Avatar
CrossFury
Wow thanks a lot guys! :D
Old Aug 19, 2014 | 04:55 PM
Capt_bj's Avatar
Capt_bj
universal?
Old Aug 20, 2014 | 12:38 AM
minsanity's Avatar
minsanity
He meant 8-hole multi-fit wheels. 4x100 & 4x114.3
Old Aug 20, 2014 | 05:02 PM
CrossFury's Avatar
CrossFury
Sorry about that . Minsanity has it right.
Old Aug 30, 2014 | 08:29 PM
CrossFury's Avatar
CrossFury
I am sorry to be blunt here. But are the ones ECS linked the ones I actually need for my car?
Old Aug 31, 2014 | 04:19 AM
myles2go's Avatar
myles2go
You have to check what size lug bolts you currently have. In late 2006 mini changed to 14mm threads. The ECS pieces shown are 12mm so if you have 14mm bolts they will not work.
Old Sep 2, 2014 | 08:35 AM
Yep,
"12x1.5x60mm for R50 R52 R53 up to 7/2006 " its marked above. 7/2006 was the split year.
ki7hy
Suspension
Mar 13, 2016 08:45 PM
FLYM1N1
Oct 13, 2015 04:33 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
TOMSR53
Aug 26, 2015 10:18 AM
