R56 Horsepower/Torque Gains
Old Aug 14, 2014 | 02:29 PM
StPeteMiniS's Avatar
StPeteMiniS
Hi everyone,
My 07 MCS has the Forge FMIC, Evolve DeCat DP and full catback exhaust. I have my boost controller ordered, and likely will have the WMW manifold ordered in a couple weeks.
I'm not sure if I should do more prior, or even after, but I'm likely getting the Evolve tune done once I have the funds, anyone have an idea of the hp/tq I'll be riding with come that time? Thanks!!
Old Aug 14, 2014 | 09:00 PM
bluefox280's Avatar
bluefox280
Why a boost controller? You only add boost without the fuel which is gutsy and risky on any vehicle.
Typically you'll run the car lean because you're over-riding the ECU's set boost parameters without any fuel change.
An ECU tune is a safe, good-bang-for-the-buck since it increase FUEL delivery with the increased boost.
Send back the controller and save up.
- Erik
Old Aug 15, 2014 | 06:01 AM
Grizld700's Avatar
Grizld700
- Erik
+1 You want to make the car faster, not turn it into a grenade on wheels
Old Aug 15, 2014 | 07:12 AM
EuroTechsAZ's Avatar
EuroTechsAZ
The car is smart enough it will open the blow off valve once it realizes it cannot control boost via wastegate anyway. Our waste gates are vacuum activated and not boost sensing/controlled like most turbo cars so manual controllers require some major rework and ecu modification.
Old Aug 15, 2014 | 07:57 AM
MontyRSVR's Avatar
MontyRSVR
map sensor is there to adjust fuel / adjust timing for pressure changes... of course it is on the factory ecu "curve".
like the last guy said... using a boost controller will be tricky, an old school AVC-1 hardset electronic boost controller would be the easiest to use to control a vacuum reference. I cant see anyway for a newer "smart" controller to work properly. I dont think its worth it... the right way these days is to get the ecu tuned for what you want.
IQRaceworks
53
Jun 28, 2024 07:29 AM
jetmechinnc
Nov 18, 2015 08:54 PM
micromini234
Sep 30, 2015 07:36 PM
Norton70
Sep 24, 2015 05:49 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
