valve cover removal
Old Aug 13, 2014 | 06:12 PM
idickers's Avatar
idickers
valve cover removal
I'm trying to remove the valve cover on my 2009 Clubman S. I've got all the bolts out, the coils, the ground, etc, but I cannot get it to come off. I'm prying with a putty knife and screwdriver, but it seems like there is something in the middle of the cover that is holding it on tight. I thought I'd ask if there were any tricks before I broke something.
Old Aug 13, 2014 | 08:47 PM
05r50's Avatar
05r50
Hopefully this is the right pic for your model,
Did you check under the cover part #4 for fasteners?
Don't know bout the clubman but there was a time when MINI used either a gasket or adhesive from a tube for the seal. Kinda depends when it rolled off the line.
Old Aug 14, 2014 | 04:44 AM
idickers's Avatar
idickers
Thanks for the quick reply. All fasteners have been removed, and I left the spark plugs in to keep stuff from falling into the combustion chamber. It does feel like there is sealant on the driver's side.
Old Aug 14, 2014 | 09:38 AM
Slave to Felines's Avatar
Slave to Felines
Got a rubber mallet? Tapping sideways (not on anything fragile!!) should loosen up any sealant that's on there.
Old Aug 14, 2014 | 10:12 AM
Just might be stuck a bit for the heat cycles on the gasket, causes it to stick a bit. . Give it a tap.
N14 Cooper S / JCW valve cover, badge, front cover, and pictures. Check through our pics of the underside.
https://www.northamericanmotoring.co...ment-help.html
Here is just the gasket. 11127572851 N14 Cooper S . JCW engine.
http://www.ecstuning.com/Search/SiteSearch/11127572851/
thanks
09R56
Nov 16, 2022 10:49 AM
bobbiemartin
Jan 20, 2016 05:28 PM
PaulWalliDumali
Aug 21, 2015 04:46 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
