scratching head. "sudden loss of power and oil smell."
Old Jul 29, 2014 | 05:59 PM
photoputz83's Avatar
photoputz83
I have a 2010 mcs with a few modifications. Exhaust, dp, intake, sprintbooster, and wheels. The other day I lost from what I figure is around 20% power. I also started to notice a burning oil smell. It happened within a period of an hour or so. Took my son to his mother's via the interstate, and on the way back.....gone. I had my intake valves cleaned less than 5k ago, and seafoam every 3k. I've heard stories of the valve cover pcv doing this, but is it the most likely culprit? Pulled a code that said it was downstream air leak post maf. Any tips, and has anyone changed valve covers/pcv and fixed this issue?
Old Jul 29, 2014 | 06:24 PM
DRoc7822's Avatar
DRoc7822
Was the code p115c? Cause if it is... good luck with trying to figure out what is causing it.
Old Jul 29, 2014 | 06:31 PM
photoputz83
No not the same number.
Old Jul 29, 2014 | 06:33 PM
cerenkov's Avatar
cerenkov
Well..what was the number?
Old Jul 29, 2014 | 06:34 PM
photoputz83
I pulled p1497. But yours relates to the same issue. Valve cover or pcv in valve cover might be a possibility. Not sure though.
Old Jul 29, 2014 | 07:47 PM
DRoc7822's Avatar
DRoc7822
Think that code has something to do with a vacuum leak. So yes, the valve cover would prolly be the culprit. Are you hearing any kind of hissing after shutting the car off?
Old Jul 29, 2014 | 08:08 PM
photoputz83
No hissing from what I can hear. The typical cool down cycle begins per usual, but no strange noises. I cleared the code around noon here, put 30 miles on and it has yet to show its face again.
Old Jul 29, 2014 | 08:10 PM
photoputz83
It is still low on power. Would plugs make a difference like that and that quickly.?
Old May 30, 2018 | 04:29 PM
sawicki's Avatar
sawicki
I highly doubt it's plugs. Pcv most likely.
sevin
May 2, 2026 06:11 AM
rob&JCW
Feb 13, 2023 07:03 PM
SunnySideUp
Aug 28, 2015 06:52 AM
danraabe
Aug 18, 2015 09:32 AM
