R56 Code P054B and no boost
Old Jul 25, 2014 | 07:24 AM
Zimm's Avatar
Zimm
Our mini has started throwing code P054B and going into a no boost mode. Usually clears after shutting the car off and restarting. But then it comes back.
Any ideas? DIY fix?
I found this on another mini site:
P054B - VANOS, exhaust-side, cold start: No closed-loop control possible
Old Jul 28, 2014 | 01:19 PM
07hardtop's Avatar
07hardtop
Any ideas? DIY fix?
Not exactly sure of a cause or cure for the code, but I'd start with checking the fuse and relay box in the engine bay. Should be on the driver side next to the ECU.
I had a loose relay last week that was causing the car to die everytime I put it in gear. It was throwing codes for MAF, vanos, valvetronic, O2 sensors.
May just be that simple. Is it idling fine or making any odd noises? The Vanos units are in the cam timing sprockets located on the passenger side of the motor. If it is a Vanos issue this is where any noise would be coming from.
Old May 18, 2015 | 06:11 AM
jontatt's Avatar
jontatt
Anyone ever find a fix for this? Thanks!
Old Apr 21, 2016 | 12:06 PM
antinym's Avatar
antinym
I just got this code. No other codes. Has anyone figured it out? I think I'm going to replace the vanos solenoid. '11 MCS.
Old Apr 21, 2016 | 04:36 PM
antinym's Avatar
antinym
I figured I'd pull the exhaust solenoid and clean and bench test it. It tested fine and that seemed to do the trick. All better now.
Old Apr 22, 2016 | 05:59 AM
BigBoost's Avatar
BigBoost
I had a buddy that had that code! Ended up being the vanos solenoid was bad!!
If i was you i would just get a new one! other ways you could have the same problem down the road!
Old Apr 22, 2016 | 07:47 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P054B 0x2D54 VANOS, exhaust-side, cold start: No closed-loop control possible.
The screens on the VANOS can get restricted over time. You can clean or replace the solenoid quite easily if needed. From the image below the red arrow shows a partially restricted solenoid and the green arrow shows a fully restricted solenoid. My suggestion is if you have determined you need a VANOS solenoid by cleaning then replace it. HERE if needed.
888.280.7799 | 6am - 5pm PST
Old May 3, 2016 | 05:16 PM
antinym's Avatar
antinym
My screen was nice and clean. But now I just threw a P0013. I suspect the solenoid is going bad.
Old May 4, 2016 | 11:35 AM
miniuy's Avatar
miniuy
+1 plus change your oil and filter
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
rob&JCW
Feb 21, 2018 02:41 PM
NHcountryman
Sep 6, 2015 11:01 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
