Drivetrain 19% and only 16lbs of boost??!
I installed a boost gauge recently. The gauge is only showing 16lbs max. What gives? Most 19%ers are showing 17-18lbs. At idle it shows -15-18in. It zero's out okay when off...
Anyone?
Anyone?
Well, I got around 17 last Oct on my PROMINI boost gauge (AutoMeter).
The set-up I had then included:
Rogue intake, with cowl mod
61mm TB
15% pulley
IK22 plugs
Magnecore wires
PB
QuickSilver catback
EvoTech ECU
I have since replaced the QS with my fabricated straight exit catback (battery box gone), and now have the UNIChip. On an equally cool day, or even cooler, same stretch of road, I'm getting 15's on this same gauge.
Would going with a much less restrictive exhaust create less boost? I doubt it's the UNIChip. Heck, it could be the gauge itself; at least that is what I've been thinking...
I recently got a CarChip E/X which captures data while driving, and I have peaked several times at over 20 pounds for intake manifold pressure. The gauge still shows 17 as my high from back in Oct. I realize that where the pressure is measured is a factor as well, and I'm ignorant in that regard...
I would think your boost should be much higher with the 19%. Maybe it has to do with a slight leak, or the gauge itself...
61mm TB
15% pulley
IK22 plugs
Magnecore wires
PB
QuickSilver catback
EvoTech ECU
Originally Posted by andy@ross-tech.com
Where did you tap? What kind of gauge? What RPM?
-Autometer mechanical. no kinks/bends, etc.
-tapped in FPR line just before manifold with a "tee".
-16lbs max at rev limiter (stock)
-no leaks
If you can, make note of the boost at a couple different RPM in a high gear (say 3k and 4k in 4th gear or higher). I'll compare it to mine.
What exhaust do you have?
I'm sure I'll get flames out the rear now! whap-bop-bop-boom!
Thanks greatgro for the confirmation. At 2.5" starting just beyond the cat, all the way straight back into a Borla Turbo muffler, I must have one of the freeest flowing catbacks out there. I guess that is why I lost some boost. It feels quicker, but heck, it could be a placebo due to the roar
. Seriously, I think this system will really shine when I start to produce even more hp (should be around 220 now)...
I'm really thinking of getting more air in with an HAI soon. Moving the air faster is the key. With the easy stuff done, then I'll need to drop some dough to get the internals though...
. Seriously, I think this system will really shine when I start to produce even more hp (should be around 220 now)...I'm really thinking of getting more air in with an HAI soon. Moving the air faster is the key. With the easy stuff done, then I'll need to drop some dough to get the internals though...
Andy, I did not factor-in ambient. What is a good number to use for subtraction? Thanks for the input.
Anyone?
Anyone?
Jason
Belt slip is certainly possible, especially with a 19%. The stock belt, including JCW, simply won't cut it with the 19% pulley. Otherwise, 16PSI doesn't sound too far off. What were you getting with your previous setup?
Reminder: A better exhaust (less restriction) will lower boost levels. Boost isn't everything. In this case it's boost + flow. My high with a 19% is 16.5lbs but I credit the lack of boost (17lb range) on my UUC exhaust. Interesting note, however, is that I can get 15lbs of boost in the upper 4k RPM range. When you consider boost per supercharger RPM, makes it seem like there is some boost leakage at high RPMs. I wonder if that "special coating" on newer (04 and 05) MINIs that is supposed to seal in higher amounts of boost better really makes a difference? MAYBE that's why the JCW makes a good amount of HP (200) for the somewhat low amount of torque (177). Maybe it's the seal "sealing" in the boost better at higher RPMs.
Dang, someone dug up this old thread?
The funny thing is, I was going to give an update on my boost today anyway..
I still have the 19%, and I only use the Gatorbacks btw, I gave the headbolts another 15 degrees and zip tied the bypass....now I max at just about 18 psi. I would say that the zip tie (Ryephix) gives me a better seal than without.
I have driven about 500 miles ( I'm at Orange County Choppers
) without any issue with my headgasket leak...
It depends....
Also, the exhaust ports are referenced by many as a stock restiction. This would also cause a decoupling of the effect of the exhaust on boost levels. but this is all theory. I'd like to see if anyone has actually measured it for the mini.
Matt
Oct 1, 2015 12:13 PM
EVMini
Sep 28, 2015 10:20 AM
mbatech
Sep 10, 2015 03:40 PM
