R56 JCW Big Brakes
JCW Big Brakes
is it worth spending the money on jcw brakes or should i go aftermarket? i can get the jcw brakes much cheaper than after market ones but is it still worth spending the pretty pennies for them? any advice would be appreciated.
100% not for the "bling" factor, I'm actually not a fan of the red calipers at all would much prefer black for the more classy look. I have not tracked yet but do have plans on doing so just not sure when. The car is push hard daily and the stock s brakes are just not doing it for me anymore, would like to know if jcw is a good route to go or just spend a decent amount more for some wilwoods. Other brake kits are out of my price range. I am looking for front and back
For a street car the complete JCW big brake kit which includes the front and rear kits is a pretty good value, and you know it will fit and work well. Plus replacement parts are easy to get.
Stock sized "S" brakes are perfectly serviceable on the street and at the track if you are running proper pads/fluid. If you get really into tracking I would skip the OEM JCW Brembos and get an aftermarket kit. Pad options will be better/cheaper and you don't have to deal with the crappy pistons in the JCW Brembos. For the money you're going to spend on brake upgrades you could do probably 2 track weekends + pads/fluid for your current brakes. That's the route I would take.
Right now I just don't have the time to do some track days. In the future I will be doing them, but for now I'm looking for bigger brakes. Since my car is still under warranty the jcw brakes would be covered, which is another main reason I am looking at them besides the good price I can get.
That said, look at the difference in price on the rotors and pads for the "S" and JCW brakes. Both OEM and aftermarket. You will see that it costs a good bit more for those big **** rotors and pads.
I'm not sure it is worth it. I run with plenty of guys that play hard and don't have the big brakes and they seem to get along just fine. Plus they can refresh theirs cheaper.
Just sayin......
I have the JCW brakes because they came with my 09 JCW. I don't track the car, etc. But they are fantastic brakes.
Just sayin......
Just sayin......
There is a set of front JCW BBK front brakes on the market place.
The rotor issue is easily solved by getting aftermarket rotors, even some that are cryo treated. As for the bigger diameter rotor, that may not always be the case either. Braking is more about how much surface area is utilized on the rotor by the pad. So while more surface area is great in dissipating heat better under braking, if you have too large a rotor, all you're doing is adding rotational mass to the hub and not getting any benefit from it.
I always thought that more surface area equals better braking rather than trying to squeeze an area of the rotor so close to the hub, there's very little grip that close to the iron hub.
I think some people are thinking braking torque and some are thinking swept area. Both have an effect on overall braking force. The bigger brakes are cool and look great. But I still wouldn't worry about it unless I was building a dedicated race car.
Sent from my Nexus 10 using NAMotoring
thebordella
Aug 31, 2015 01:37 PM
