R56 My window is possessed!
Old Jul 11, 2014 | 07:04 AM
sharpstick's Avatar
sharpstick
I have an 08 Cooperr S. My passenger side window is acting strangely. When I push the button to raise the window, the window will go up then hit the top (or close to the top) then come back down on its' own and stop at the half way point. The only way I can raise my window all the way up is by hittin the window button multiple times and raising the window in once increments. Any ideas or suggestions?
Old Jul 11, 2014 | 08:02 AM
nine5raptor's Avatar
nine5raptor
Reinitialize it.
Hold up for 10 seconds once it stops and then hold down for 10 seconds once it stops.
Actually you may want to verify that with a quick search. It is roughly along those lines though
Sent from my Nexus using NAMotoring
Old Jul 11, 2014 | 08:06 AM
En Fuego Mark's Avatar
En Fuego Mark
My sunroof does the same thing. I'll have to try that.
Old Jul 11, 2014 | 08:07 AM
nine5raptor
I've done a variation on that or that sequence after they freeze shut in the winter and need to be reset. Had the half open issue before as well.
Old Jul 11, 2014 | 08:15 AM
go_mini's Avatar
go_mini
my other car does the same thing. it has push/pull buttons to roll up/down the windows. After i done some research, it was just dirt stuck in the button.
Old Jul 11, 2014 | 08:26 AM
nine5raptor
I should clarify that I do not have a sunroof so I can't help there
Old Jul 12, 2014 | 01:36 PM
Sandwalk3r's Avatar
Sandwalk3r
Originally Posted by nine5raptor
Reinitialize it.
I have had this problem in the past, and I didn't know this was a fix for it.
I just told the Louisville dealer about it, and they fixed it.
Mine has already gone back out again (driver's side both times), and I've been just trying to time it right to stop it at the top.
Time to go try this.
Old Jul 12, 2014 | 02:14 PM
Sandwalk3r's Avatar
Sandwalk3r
I wasn't able to get the reset to work ;(
Old Jul 12, 2014 | 02:41 PM
nine5raptor
Found some that say hold down for 10 then up for 10.
Others say hold up for 15 then remove the fob.
Others disconnected battery and say it worked.
Some just go to the dealer.
Probably involves standing on your head and patting your belly while whispering sweet nothings to it.
I know I have reset mine myself though by hold up/down or down/up for at least 10 secs each way. 2010 mcs BTW.
Old Jul 13, 2014 | 04:24 PM
Mini3333's Avatar
Mini3333
you're not the only one with this problem.
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
semibreve42
Oct 2, 2015 09:06 AM
rt808
Sep 25, 2015 01:59 PM
