R50/53 Squeaky sunroof
Squeaky sunroof
Occasionally my sunroof will squeak while opening, so I figure it needs a good cleaning and lube. I'm guessing I could spray a bit of degreaser in the sunroof tracks then apply some new lube. That sound about right? Or, is there some other proper cleaning and maintenance procedure for the sunroof?
Also, what sort of lube should I use and where exactly should I apply it. Also, where are the drain plugs located. If I'm cleaning the tracks I want to be sure and run some weed whacker line down through the drain lines.
Thanks,
Mark
Thanks,
Mark
R50/53 Help please.. Odd issue.
PsychoRallye
21
Feb 17, 2019 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
Jim Ferrell
Oct 6, 2015 08:09 AM
