How To Auxilary Driving Lights Installion Instructions
Old Jul 9, 2014 | 07:59 PM
GregoryK's Avatar
GregoryK
Here are the workshop instructions for installing the Auxilary Driving lights for cars with and with out LED Headlamps.
Please be aware that there is a mistake in the LED Light instructions lead A9 Does not connect to pin 1 as stated it connects to pin 20 as shown in the wiring diagram.
Also if you are from Canada A9 and A10 connect to different leads than shown in the US install instructions
A9 connects to Pin 4 of plug A258*4B
A10 connects to Pin 41 of plug A258*2B
I am in Canada and I have tested these and they work.
Also you will have to pull the front bumper to install these. I have a posting on how to do this.
Please don't pay to have these installed. It is extremely satisfying to do this yourself! I have photos of most of my install (including how to penetrate the firewall and pulling the trim). If required I will post these.
Good luck!
File Type: pdf
File Type: pdf
Old Jul 9, 2014 | 09:05 PM
David Cottrell's Avatar
David Cottrell
Good luck!
Maybe I should link this to my dealer as my car is in the shop for 3 days now getting these installed and they cannot get them to work. The only reason it there is because they are free for me.
Old Jul 9, 2014 | 10:20 PM
eurospek's Avatar
eurospek
Thanks for posting!
Old Jul 10, 2014 | 03:21 AM
veggivet's Avatar
veggivet
My dealer quoted 6 hours of labor for this job! Total estimate including OEM driving lights was $1300! I went aftermarket…
Thanks for posting!
Old Jul 10, 2014 | 04:44 AM
DarkBlue15MCS's Avatar
DarkBlue15MCS
Originally Posted by veggivet
My dealer quoted 6 hours of labor for this job! Total estimate including OEM driving lights was $1300! I went aftermarket… Thanks for posting!
I decided to go aftermarket as well due to the same cost. Now I just have to find F56 brackets.
Old Jul 10, 2014 | 04:47 AM
veggivet's Avatar
veggivet
www.vipcustomparts.com is where I ordered mine.
Old Jul 10, 2014 | 04:48 AM
DarkBlue15MCS
I'll check it out. Thanks!
Old Nov 6, 2014 | 10:35 AM
Here is the part # for the rally lights:
Driving Lights Retrofit Kit - Chrome Part # 63210420292
http://www.ecstuning.com/Search/SiteSearch/63210420292/
Driving Lights Retrofit Kit - Black Part #63120417885
http://www.ecstuning.com/Search/SiteSearch/63120417885/
Then bracket:
Rally Light Brackets - Pair 63122355769
http://www.ecstuning.com/Search/SiteSearch/63122355769/
Then the button for the interior: 51452355772
http://www.ecstuning.com/Search/SiteSearch/51452355772/
Then if you have the LED light option you will need this also. 63122284922
Auxiliary Kit For Interface
http://www.ecstuning.com/Search/SiteSearch/63122284922/
F56 MINI Cooper SET UP;
Old Nov 6, 2014 | 10:40 AM
Rajapruk's Avatar
Rajapruk
When will the LED rally-lights shown in Paris be available for order, do you know that ECSTuning?
Old Nov 6, 2014 | 10:45 AM
MikewithaMini's Avatar
MikewithaMini
Pick up some Posi-tap (Posi-Products) wire connector\splicers in lieu of what is supplied in the kit. You'll be glad you did for the space these sometimes have to fit into. It makes for a more secure connection (in my opinion) and a cleaner install.
Old Nov 6, 2014 | 10:50 AM
" When will the LED rally-lights shown in Paris be available for order, do you know that ECSTuning? "
Nothing yet ,maybe down the road, they do look pretty cool. We did have to wait for the LED DRL s for a while here in the US.
Old Nov 6, 2014 | 10:57 AM
Crimguy's Avatar
Crimguy
Here is the part # for the rally lights: Driving Lights Retrofit Kit - Chrome Part # 63210420292 http://www.ecstuning.com/Search/SiteSearch/63210420292/ & Driving Lights Retrofit Kit - Black Part #63120417885 http://www.ecstuning.com/Search/SiteSearch/63120417885/ Then bracket: Rally Light Brackets - Pair 63122355769 http://www.ecstuning.com/Search/SiteSearch/63122355769/ Then the button for the interior: 51452355772 http://www.ecstuning.com/Search/SiteSearch/51452355772/ Then if you have the LED light option you will need this also. 63122284922 Auxiliary Kit For Interface http://www.ecstuning.com/Search/SiteSearch/63122284922/ Thanks
Where exactly does that button/switch go? Someone said in another thread that his is on the side of the steering column?
Old Nov 6, 2014 | 11:05 AM
Check out the second PDF at the top.
The Switch goes on the right side of the steering column,. Kind of different for MINI.
Old Nov 10, 2014 | 11:03 AM
Looks like the F56 , also works for the kits ( R56- R61 MINI ) led rally lights are out ! Also looks like a direct swap from the normal halogen units. So if you get these or have the regular halogen versions, looks like a direct swap. Just need that parts linked above.
Pic from the R56 set up. But #1 is shared between kits on the R56-R61 -F56 ( #2 and #3 are for the R56-R59 MINI ONLY ) The F56 just needs the F56 brackets linked up above.
F56 SET UP
#1 LED Driving Lights Retrofit Kit - Black 63122288982
http://www.ecstuning.com/Search/SiteSearch/63122288982/
OR
#1 LED Driving Lights Retrofit Kit - Chrome 63122288981
http://www.ecstuning.com/Search/SiteSearch/63122288981/
F56 MINI Cooper 2014+ w/ LED rally lights installed.
Have not seen them light yet , but they look like they similar the DRL LED set ?
Old Nov 10, 2014 | 11:37 AM
Rajapruk's Avatar
Rajapruk
Nice!
But I do not like the extra switch. Would like them to operate togheter witht the normal headlight. Is that possible?
Old Nov 10, 2014 | 11:53 AM
Welcome.
I am sure you could wire it that way. Check out the toggle wire , its a four post feed switch. That's I info I have.
Old Nov 24, 2014 | 05:57 PM
sal1k's Avatar
sal1k
I'm confused, does the kit only retrofit already existing rally lights?
What is the out of pocket cost (for parts only) if you don't have any rally lights installed?
Old Nov 24, 2014 | 09:26 PM
Crimguy's Avatar
Crimguy
Originally Posted by sal1k
I'm confused, does the kit only retrofit already existing rally lights? What is the out of pocket cost (for parts only) if you don't have any rally lights installed?
From what I've seen online using oem parts, including lights, switch and a bracket for bumper will cost around $430
Old Nov 25, 2014 | 04:58 AM
Yes, you can swap out to the new LED fixture part linked above , if you already have the halogens installed.
All the parts are linked above. If you don't have them also.
Old Nov 26, 2014 | 10:09 AM
Moflash1's Avatar
Moflash1
I currently have halogen driving lights installed on my F56 with led headlamps.
What would be required to convert to the new led driving lights??
Old Nov 26, 2014 | 10:31 AM
GregoryK's Avatar
GregoryK
I have the Halogen headlamps but am running Pia bulbs. I had the same lights on my R56. I personally would not waste money upgrading. I have the LED headlamps and honestly found the Xenon headlamps on my F56 to be better at night on a dark mountain road. The driving lights really don't add much to the lighting and are really a retro-cool thing. Save your money.
Old Dec 25, 2014 | 09:04 AM
subguy658's Avatar
subguy658
Hi all - just got the chrome kit for Christmas from my kids. I have seen the post about the bumper removal, but none for how to get the interior pieces off. Anyone have any information on that?
Old Dec 29, 2014 | 10:58 AM
The second PDF "Retrfoti_DrivingLamps_F56_01.pdf" linked all the way at the top shows the install on the interior and the switch that goes on the steering column panel.
Old Dec 29, 2014 | 01:21 PM
subguy658's Avatar
subguy658
Looking for panel removal
Hi and thanks. I have the pdfs for the wiring and all. What i dont have are the ones that tell how to get the knee bolsters and glove box off without damaging anything
Old Dec 30, 2014 | 11:33 AM
I don't have the PDF , but I did link some parts digrams to help :
#3 is the driver side knee bolster. #1 and #2 are those steering column covers.
#1 is the glove box
Thanks and good luck.
