Auxilary Driving Lights Installion Instructions
2 Attachment(s)
Here are the workshop instructions for installing the Auxilary Driving lights for cars with and with out LED Headlamps.
Please be aware that there is a mistake in the LED Light instructions lead A9 Does not connect to pin 1 as stated it connects to pin 20 as shown in the wiring diagram. Also if you are from Canada A9 and A10 connect to different leads than shown in the US install instructions A9 connects to Pin 4 of plug A258*4B A10 connects to Pin 41 of plug A258*2B I am in Canada and I have tested these and they work. Also you will have to pull the front bumper to install these. I have a posting on how to do this. Please don't pay to have these installed. It is extremely satisfying to do this yourself! I have photos of most of my install (including how to penetrate the firewall and pulling the trim). If required I will post these. Good luck! |
Originally Posted by GregoryK
(Post 3959800)
Thanks for posting!
My dealer quoted 6 hours of labor for this job! Total estimate including OEM driving lights was $1300! I went aftermarket…
Thanks for posting! |
Originally Posted by veggivet
(Post 3959880)
My dealer quoted 6 hours of labor for this job! Total estimate including OEM driving lights was $1300! I went aftermarket… Thanks for posting!
www.vipcustomparts.com is where I ordered mine.
When will the LED rally-lights shown in Paris be available for order, do you know that ECSTuning?
Pick up some Posi-tap (Posi-Products) wire connector\splicers in lieu of what is supplied in the kit. You'll be glad you did for the space these sometimes have to fit into. It makes for a more secure connection (in my opinion) and a cleaner install.
" When will the LED rally-lights shown in Paris be available for order, do you know that ECSTuning? "
Nothing yet ,maybe down the road, they do look pretty cool. We did have to wait for the LED DRL s for a while here in the US. |
(Post 4010415)
Here is the part # for the rally lights: Driving Lights Retrofit Kit - Chrome Part # 63210420292 http://www.ecstuning.com/Search/SiteSearch/63210420292/ & Driving Lights Retrofit Kit - Black Part #63120417885 http://www.ecstuning.com/Search/SiteSearch/63120417885/ Then bracket: Rally Light Brackets - Pair 63122355769 http://www.ecstuning.com/Search/SiteSearch/63122355769/ Then the button for the interior: 51452355772 http://www.ecstuning.com/Search/SiteSearch/51452355772/ Then if you have the LED light option you will need this also. 63122284922 Auxiliary Kit For Interface http://www.ecstuning.com/Search/SiteSearch/63122284922/ Thanks
Check out the second PDF at the top.
The Switch goes on the right side of the steering column,. Kind of different for MINI. Thanks |
Originally Posted by Rajapruk
(Post 4010418)
Looks like the F56 , also works for the kits ( R56- R61 MINI ) led rally lights are out ! Also looks like a direct swap from the normal halogen units. So if you get these or have the regular halogen versions, looks like a direct swap. Just need that parts linked above. -------------------------------------------------------------------- Pic from the R56 set up. But #1 is shared between kits on the R56-R61 -F56 ( #2 and #3 are for the R56-R59 MINI ONLY ) The F56 just needs the F56 brackets linked up above. http://www.etk.cc/bmw/images_etk/B0075068.png -------------------------------------------------------------------- F56 SET UP http://www.etk.cc/bmw/images_etk/B0068034.png #1 LED Driving Lights Retrofit Kit - Black 63122288982 http://www.ecstuning.com/Search/SiteSearch/63122288982/ http://c1552172.r72.cf0.rackcdn.com/644804_x600.jpg OR #1 LED Driving Lights Retrofit Kit - Chrome 63122288981 http://www.ecstuning.com/Search/SiteSearch/63122288981/ http://c1552172.r72.cf0.rackcdn.com/622556_x600.jpg F56 MINI Cooper 2014+ w/ LED rally lights installed. http://i.kinja-img.com/gawker-media/...d7tsr7ibz8.jpg Have not seen them light yet , but they look like they similar the DRL LED set ? |
Nice!
But I do not like the extra switch. Would like them to operate togheter witht the normal headlight. Is that possible? |
Welcome.
I am sure you could wire it that way. Check out the toggle wire , its a four post feed switch. That's I info I have. :) |
I'm confused, does the kit only retrofit already existing rally lights?
What is the out of pocket cost (for parts only) if you don't have any rally lights installed? |
Originally Posted by sal1k
(Post 4016884)
I'm confused, does the kit only retrofit already existing rally lights? What is the out of pocket cost (for parts only) if you don't have any rally lights installed?
(Post 4016884)
What is the out of pocket cost (for parts only) if you don't have any rally lights installed? All the parts are linked above. If you don't have them also. :thumbsup: |
I currently have halogen driving lights installed on my F56 with led headlamps.
What would be required to convert to the new led driving lights?? |
I have the Halogen headlamps but am running Pia bulbs. I had the same lights on my R56. I personally would not waste money upgrading. I have the LED headlamps and honestly found the Xenon headlamps on my F56 to be better at night on a dark mountain road. The driving lights really don't add much to the lighting and are really a retro-cool thing. Save your money.
Hi all - just got the chrome kit for Christmas from my kids. I have seen the post about the bumper removal, but none for how to get the interior pieces off. Anyone have any information on that?
The second PDF "Retrfoti_DrivingLamps_F56_01.pdf" linked all the way at the top shows the install on the interior and the switch that goes on the steering column panel.
Looking for panel removal
Hi and thanks. I have the pdfs for the wiring and all. What i dont have are the ones that tell how to get the knee bolsters and glove box off without damaging anything :)
I don't have the PDF , but I did link some parts digrams to help :
#3 is the driver side knee bolster. #1 and #2 are those steering column covers. http://www.realoem.com/bmw/diagrams/e/i/534.png #1 is the glove box http://www.realoem.com/bmw/diagrams/k/z/560.png Thanks and good luck. |
