Drivetrain Exhaust Burble on gear upshift
Old Jul 9, 2014 | 10:52 AM
Mayfair's Avatar
Mayfair
Hi guys,
Few weeks ago, I saw a R56 S drive by me. It did a burble on each gear shift (while upshifting). I have a 2012 R56 S and it does pop and burble, but only when I let go off the gas under high rev or when I downshift.
I'm not sure what modification were done on that car, and am looking if someone has any idea or have heard anything similar.
I drove an Audi S4 the other, it did a similar burble on every gear change. It is so addictive
Any advice please
Old Jul 9, 2014 | 11:41 AM
Grizld700's Avatar
Grizld700
What mods do you have on your car now?
Old Jul 9, 2014 | 12:01 PM
pelicanpirate's Avatar
pelicanpirate
Certain years of the Cooper S Turbo will do this in Sport Mode.
Old Jul 9, 2014 | 12:18 PM
Rory's Mini's Avatar
Rory's Mini
burble on upshift
My 2012 JCW Clubby does that! I've only had it a month.
Old Jul 9, 2014 | 12:46 PM
Mayfair's Avatar
Mayfair
I've just done the resonator delete. Recently I installed the Burger Motorsport JB+ tune.
Old Jul 9, 2014 | 12:54 PM
Grizld700's Avatar
Grizld700
Stock S exhaust?
Old Jul 9, 2014 | 01:48 PM
a2oc's Avatar
a2oc
stock N18 engine cooper S will have the pop and burble in sport mode , should be 11-13 LCI cooper s
Old Jul 9, 2014 | 03:18 PM
ptguy0618's Avatar
ptguy0618
I've noticed it depends on which rpm you shift at, I can get a pop on every shift at 2500-2800 rpm, just gotta find the money spot, it will even do it on down shifts every lucky once in a while!
Old Jul 9, 2014 | 03:53 PM
Mayfair's Avatar
Mayfair
Stock S exhaust?
Yes, it's stock exhaust.
Old Jul 21, 2014 | 11:27 AM
Ovrclck's Avatar
Ovrclck
If only the 2010 MCS could burble! :(
Old Jul 23, 2014 | 06:59 PM
johntotah94's Avatar
johntotah94
Probably had an exhaust or is catless. Mine pops non stop ever since I did both. Pops a lot more and is a louder pop.
Old Jul 26, 2014 | 07:04 PM
Ovrclck's Avatar
Ovrclck
I just noticed since adding the JCW exhaust with resonator and 2nd cat removed. I'm able to pop on every up shift/letting off the gas, but only when the engine hasn't warmed up yet. Sounds awesome.
Sent from my Note 3 using NAMotoring
Old Jul 28, 2014 | 12:11 PM
Cary Cooper's Avatar
Cary Cooper
Calico Jack will pop/burble on upshifts, but ONLY if I get lazy shifting slow rather than shifting/engaging the clutch at a more "normal" speed. When engaging the clutch more quickly upshifting he neither pops nor burbles. Downshift rev-matching, he pops/burbles as normal. No mods (yet) in engine/exhaust system - stock components.
Old Apr 6, 2017 | 12:24 PM
97nicolaus's Avatar
97nicolaus
Is your S4 and cooper S automatic? I noticed automatic cars with sport exhaust or sport mode these days will "fart" on every upshifts. Auto tranny F series mini cooper S will have those farts as well with exhaust mods. I have an auto R61s and removed the muffler, but it does not have those pop and burble sound when I upshift, only at downshifts when at higher rpm.
Old Apr 7, 2017 | 05:44 AM
HasAnMTBProblem's Avatar
HasAnMTBProblem
Aftermarket exhaust, especially with 2nd cat delete and resonator delete will make the P&B's more pronounced.
Old Feb 6, 2018 | 09:56 PM
bongshi4's Avatar
bongshi4
2nd cat and res removal
If you own 2.5 gen (2012+), you don't need an aftermarket exhaust, it can be done with stock exhaust also.
Engine must be warmed up first, and if you put on sport mode, it will start generate pops from exhaust.
If you are looking for louder and more pops, remove 2nd cat and resonator, it will give you much more pops!!
[YOUTUBE][url]https://youtu.be/lkrutQy6Bo0
bongshi4's Avatar
bongshi4
[QUOTE=bongshi4;4366031]If you own 2.5 gen (2012+), you don't need an aftermarket exhaust, it can be done with stock exhaust also.
You Tube
"> You Tube
" type="application/x-shockwave-flash" width="425" height="350">
Old Feb 7, 2018 | 06:49 AM
cornjuice's Avatar
cornjuice
Look for a stock JCW exhaust .. enjoy.
Philipangoo
Sep 16, 2015 11:54 AM
imanexcellentdriver
Aug 31, 2015 08:08 PM
cmanlu
R58 :: Coupé Talk (2012+)
Aug 25, 2015 07:35 AM
Aug 12, 2015 01:24 PM
