R50/53 Rear fog light wiring question
Old May 29, 2014 | 05:18 PM
P4pumpman's Avatar
P4pumpman
Have 05 justa . My mini is already pre-wired for a rear fog light but I don't have a switch in the panel for it . Can someone give me advice on what to do . Is it possible to wire it in so it will come on with my front fogs ?
Any advice , tips or tricks would be great .
Thanks .
Old May 29, 2014 | 07:27 PM
Sp4rtan's Avatar
Sp4rtan
Assuming you have the factory fogs, all that should be necessary is to hook it up and probably have the computer re-programmed. You might be lucky and not have to, but that doesn't seem to be how things work.
Old May 29, 2014 | 09:17 PM
rkw's Avatar
rkw
The basic steps are:
  1. Install the rear fog lamp, and plug in the pre-wiring.
  2. Swap your toggle panel with one that has a full set of switches. Shop for a used panel on eBay, or new one costs about $160 (http://www.ecstuning.com/Mini-2005-C...itch/ES167631/).
  3. Have a dealer activate it on the computer.
The official instructions are here: https://www.northamericanmotoring.co...t_Retrofit.pdf
Old May 30, 2014 | 05:42 AM
P4pumpman's Avatar
P4pumpman
Thanks for the detailed info and part numbers .
Is it possible to wire the rear fog light to the front fog lights . I thought maybe I could piggyback off the front fog lights so when I hit the the one switch , they both come on . Has anyone ever done this .
Old May 30, 2014 | 05:49 AM
astroBlackMetallic_Mini's Avatar
sure. just run a wire! ive done lots of that type of wiring to my mini. Your biggest concern will be whether you want to run it on the inside or outside of the car; should be a pita regardless, so dont worry
ive hard wired the rear fog to come on with regular lights, same with the front fogs. i dont even use the switches anymore.
fwiw, you may want to consider swapping that rear fog Bulb to an LED. mine was getting very hot with continual usage; alarmingly hot actually.
Old May 30, 2014 | 06:34 AM
CoolioMcPimp's Avatar
CoolioMcPimp
Anyone add custom LED illuminated switches to their switch panel? I wouldn't mind having the tip of the switch glow orange when the rear fog is on.
Old May 30, 2014 | 06:35 AM
lol. good news! it already comes like that!
Old May 30, 2014 | 08:13 AM
P4pumpman's Avatar
P4pumpman
Cool . As much as I would love to do it right and get the new toggle bank but $250 + dealer fee to reprogram it just to have a rear fog is a lot to pay . I'll look into running a wire from the back to the front and piggyback off my front fogs so when I hit the switch the rear will come on to.
Old May 30, 2014 | 08:17 AM
rkw's Avatar
rkw
Really? The rear fog is annoyingly bright and makes you look like you're driving around with a brake light stuck on. Better to wire it to the brakes instead.
Old May 31, 2014 | 06:02 AM
CoolioMcPimp
I like the idea of an added reverse light instead. Get the clear lens instead of the red. Wire it to reverse lights. If you have tinted windows it makes it a lot easier to see at night.
Old May 31, 2014 | 08:38 AM
ti22fjc's Avatar
ti22fjc
Old May 31, 2014 | 03:10 PM
rkw's Avatar
rkw
I went with the kitchen sink approach: https://www.northamericanmotoring.co...d-extreme.html
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
