R50/53 2005 Cooper S Dead Key Issue
Old May 24, 2014 | 07:44 AM
Buggy's Avatar
Buggy
Original owner of a 2005 Cooper S that came with two keys. Apparently the battery inside the key can not be replaced and no longer holds a charge while driving. Both keys have exhausted their battery lives and the dealer say it's $280.00 per key to replace each one.
Was wondering if anyone has faced this same issue and has found a way to resolve it instead of getting ripped off by the dealers.
Thanks in advance!
Old May 24, 2014 | 08:56 AM
IDNTFIT's Avatar
IDNTFIT
I was told by my service tech that the key fob for my 2007 MCSc would only cost 150.00 . He did say that because my key was a newer type that they wouldn't have to charge labor fees for a tech to reprogram it. Perhaps that is why your quote was so high?
Old May 24, 2014 | 09:52 AM
ZippyNH's Avatar
ZippyNH
Try another dealer....
Cost DOES vary...
They will ask for proof of ownership before you can order the key...
Old May 24, 2014 | 10:55 AM
rkw's Avatar
rkw
A few on this forum have successfully replaced the rechargeable battery in the 05-06 key. You'll have to cut open the key cover (and glue it back together afterwards). The battery is soldered in place and you'll have to unsolder to remove it. The replacement battery only costs a few dollars each.
Old May 24, 2014 | 02:21 PM
rwkeating's Avatar
rwkeating
Any instructions on how to do that (cut it open)? Do you know the part number or type of battery? Just trying to be prepared since mine is a 2006 and not sure how much longer the keys will last.
Old May 24, 2014 | 05:10 PM
rkw's Avatar
rkw
Here's the thread: https://www.northamericanmotoring.co...ob-repair.html (also note post#5 has a couple of links to repair services, if you don't want to attempt it yourself).
Old May 24, 2014 | 05:58 PM
Buggy's Avatar
Buggy
RKW,
Can't thank you enough for that thread reference!
I will be updating my experience with this method early next week.
Buggy
Old May 26, 2014 | 03:25 PM
Call's Avatar
Call
I cut open the fob with a razer blade. If you take your time it is fine. The battery was a pill but I used the same blade to cut through the soldered battery. Take your time. Then just inserted the battery and glued everything back like new.
iggi
18
Feb 9, 2026 01:00 AM
Toolman
Jan 20, 2016 06:50 AM
mdutton11
14
Oct 26, 2015 01:47 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
CARdiac
Aug 8, 2015 03:30 PM
