R56 where do two new run flats - go?
Old May 21, 2014 | 09:28 AM
bardot861's Avatar
bardot861
Hello:
My 2007 mini S - 79K miles has been going through sets of tires - as would
be expected. Running Kumho 205 45 R17 Ecsta Vr Spt.
In previous changes where two new were being mounted - had them mounted to front - and the fronts staying in left /right position moved to rear. Now - finding strong recommendation that the new are to be mounted - consistent with directional indication on tire - that the new must go on back??
Thought front driver works the front tires the hardest and consistent with what would normally be tire rotation - have previously mounted new pair to front. Be interested in knowledgeable opinion on this.
Regards,
Barry
Old May 21, 2014 | 10:05 AM
Mcameron's Avatar
Mcameron
my general rule of thumb is the newer tires go in the front.....
....as those are the wheels that handle the driving, steering, and more importantly, the bulk of the breaking.
Old May 21, 2014 | 10:26 AM
jcauseyfd's Avatar
jcauseyfd
Most of the tire companies and manufacturers recommend new tires go on the rear in order to minimize the chances of an unrecoverable oversteer condition developing.
Old May 21, 2014 | 10:35 AM
Mib4840's Avatar
Mib4840
Jump on Tire Rack and read what they have to say. I just finished reading a bunch of info and learned a lot! They say new tires always on rear, and it makes sense why after you read the explanation.
Old May 21, 2014 | 07:07 PM
BlackMagicMini's Avatar
BlackMagicMini
If front tires are very worn, in a hard cornering situation the front will plow. If you put the very worn tires on the back and you encounter a very hard cornering situation the rear will break away and oversteer resulting in a dangerous loss of control. This situation may occur on slippery roads. You never want the back of the car to break away as its difficult to control for most drivers. Therefore the reco to put better tires on the rear.
Old May 22, 2014 | 06:59 PM
wonshot's Avatar
wonshot
I can say that the new tires should go on the rear, its more for braking purposes in the wet/snow. I am in the tire business and have been for the past 25 years. I still get people insisting that the new go on the front and after a little education, we are mounting the new tires on the rear.
As for it being a Run Flat tire, it doesn't matter same rules apply, the fact that the sidewalls are stiffer for RFT doesn't really change that much on tire "rules". Just as an example Bridgestone has developed a run flat tire that is made for almost every passenger vehicle applications as long it has TPMS.
Sorry for the lengthy reply, but I hear this about 10x a day.
Old May 22, 2014 | 07:11 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
We always recommend doing sets for four with an alignment. Rotate with every 5K oil change. We also never recommend run flats.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old May 23, 2014 | 06:57 PM
Ex Z3Coupe's Avatar
Ex Z3Coupe
the garbage with the other 2 !
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
jziran
Aug 24, 2015 04:50 PM
