Drivetrain loose SC pulley
Old Apr 30, 2014 | 11:33 PM
Javskies's Avatar
Javskies
loose SC pulley
so i have a problem where my m7 16% pulley will no lock onto the sc shaft. i put the inner collet half all the way til it hits the seal. then i push the second half of the pulley on, i even lightly tap it with a mallet to make sure it goes all the way, then i screw in the 4 hex bolts but the pulley just freely spins on the shaft and i can just slide it off the shaft. has anyone experienced this problem? appreciate any help given!
Old May 1, 2014 | 04:55 AM
ZippyNH's Avatar
ZippyNH
Sounds like the shaft is damaged from the pulley slipping....bolts should have been on super tight, with some thread locker/locktight.....
The altav2 has a different mounting system that is more tolerant to shaft damage.... So you might get one of those on.....
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
