Yellow Engine Light & Limp Mode
Old Apr 24, 2014 | 05:29 PM
rockridge's Avatar
rockridge
Just had the timing chain replaced along with guide and tensioner last week. Upon cold start (first start of the day) Car will now trigger the "yellow half engine" icon on instrument cluster, and you can feel the car has no power. Car will drive like this for about 2-3 minutes, and then return to normal, and run that way the remainder of the day.
Read the codes and they are
P2D50
P2D9C
The car only has 38,000 miles, I had the valves blasted with walnut shells at the dealer 2 years back.
While I have an accessport, this is happening on the standard JCW tune.
Any Ideas?
Old Apr 25, 2014 | 11:09 AM
bmx045's Avatar
bmx045
something to do with the DME and speed control
tough getting a clear answer on those particular codes.
Old Apr 25, 2014 | 12:04 PM
rockridge's Avatar
rockridge
Dealer is sending tow truck to pick up the car and evaluate it.
Old May 4, 2014 | 04:08 PM
rockridge's Avatar
rockridge
Turns out when they replaced the timing chain, they did not tighten the NM Engineering charge pipe properly. It was leaking are, and caused the Yellow engine light. The codes were a result of the engine going into limp mode, not the cause.
Old May 4, 2014 | 05:02 PM
Systemlord's Avatar
Systemlord
So you're saying it was the NM pipe?
Whenever I have something done to my MCS I always inspect everything and clean the mechanics dirty fingerprints. After my dealer replaces my clutch Monday or Tuesday I will be inspecting every wire connection, shifting cables and coolant hoses to make sure everything is tight.
Old May 5, 2014 | 04:56 AM
rockridge's Avatar
rockridge
Yes, It was the clamps on the NM charge pipe that were not tight. Lesson learned.
Etrain
16
Aug 5, 2024 04:37 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
