R57 Burned out light bulb indicator light
Old Apr 21, 2014 | 04:58 PM
wmsue's Avatar
wmsue
I'm getting the burned out light bulb indicator on my dash but I can't find any bulb that's out. I had this happen last year and the dealer changed a part and all was well. Is this a common problem that I should expect? Anybody else having this happening to theirs?
Old Apr 29, 2014 | 05:44 PM
azwildbill2's Avatar
azwildbill2
Mine ended up being the license plate light. I didn't notice it when I walked around the car.
Old Apr 30, 2014 | 04:35 AM
wmsue's Avatar
wmsue
I double checked the license plate light and found that both of them are OK. Did a walk around and couldn't find the culprit.
What I have noticed is that the indicator doesn't come on all the time. I drove home from work yesterday (45 miles) and the light was not on. This morning is was on all the way to work. Over the weekend it was not on at the beginning of my drive to Cleveland, but after about a half hour it came on. Sounds like a loose wire or circuit board to me. Hope it doesn't have anything to do with the raccoon that I hit a month or so ago. It took a few weeks for the light to first come on after the accident.
Thanks for the reply
Bill
Old May 3, 2014 | 10:24 AM
wmsue's Avatar
wmsue
Found out the problem......I think
So, I had my wife stand behind (and off to the left a bit) my car to see if the backup lights come on. Found out that neither the backup or brake light come on in the 3 bulb unit in the rear bumper. Took it apart and all the bulbs were good but no power was getting to the bulbs. Took the connector apart and found one of the prongs burned out. Not sure how well it shows in the photo, but hopefully this will help someone else out in the future.
Attached Thumbnails Burned out light bulb indicator light-reverse-light-connector.jpg
Old Jul 11, 2014 | 11:47 PM
sjp3003's Avatar
sjp3003
Thanks this has been driving me nuts for the past few weeks... the warning light comes on then goes away for no apparent reason. I'll see if it is the same connector.
Old Mar 14, 2015 | 12:46 PM
wmsue's Avatar
wmsue
Deja Vu
It's at it again.
I had the problem fixed by the dealer before the warranty expired, but now at 43K it's on me. I took it apart today and found 2 spliced wires that the Mini dealer repaired but it looks like they never replaced the long black plastic piece nor the connector. Here's a photo of what I need. It has part # OLSA 03.455.04.0 on it and it houses the 2 backup lights and the brake light. I also need the connector plug that goes into it to properly repair the situation. If the price is too high, I'll bet I could solder a wire to the inside and feed it through a small hole and splice.
Attached Thumbnails Burned out light bulb indicator light-light-cover-1.jpg   Burned out light bulb indicator light-light-cover-2.jpg
Old Jun 28, 2015 | 09:39 PM
VICTOR HUGHES's Avatar
VICTOR HUGHES
I have the same issue no bulb burned out and all lights are working!
Old Jul 6, 2015 | 12:59 PM
This is the housing : That's for the R56 R57 Cooper ( NON S ) 2011+ 63247297417
http://www.ecstuning.com/Search/SiteSearch/63247297417/
Old Jul 17, 2015 | 11:48 AM
wmsue's Avatar
wmsue
That's the part I needed. I ended up repairing mine because the 4 prong connector was fried and I could not find a replacement. When I called you (ECS) the rep told me that he could only find a 3 prong connector. I wouldn't mind fixing mine the proper way if you have a connector available now.
Bill
Old Jul 17, 2015 | 12:28 PM
We have the whole thing linked above and its available Sorry they could not find it. You can always shoot me a PM.
Old Sep 18, 2017 | 04:32 PM
Coreyjames's Avatar
Coreyjames
Rear fog lights
Hello. I need the three bulb bar as well. And possible the switch that plugs into it as well cause I'm worried the prongs broke off in the switch. Is the switch available somewhere ? The one that has wires and plugs into the bar??
Thank you
Old Sep 20, 2017 | 08:57 AM
Can you get me a picture of that plug on the wire side as its not in the parts diagram, then i can cross ref it.
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
