FS:: 6 Speed Getrag Conversion
Old Apr 16, 2014 | 06:58 PM
PBandJay's Avatar
PBandJay
6 Speed Getrag Conversion (Sold)
Price: $675
Part fits (you may select multiples): R50, R53
ITEM IS SOLD. If someone wants to tell me how to delete a post, I'd be more than willing to remove it.
I just finished parting out my 2003 Mini Cooper and I think I have all the parts needed for a 6 Speed conversion (as far as I know). So if you're want to ditch the CVT take a look. Here's the list of components
-6 Speed Getrag
-Cast aluminum Mounts to mount tranny to chassis. There are two, one attached to the tranny and on the chassis
-Dual Mass Flywheel
-Starter Motor (it is different from the CVT)
-Brake and clutch Pedals
-Clutch master Cylinder
-Clutch Slave Cylinder
-Clutch line from Master cylinder to slave
-Clutch line from Brake fluid reservoir to Clutch master cylinder
-Shifter
-Shifter cables
-Shifter ****
Price does not include shipping
Old Apr 16, 2014 | 08:48 PM
gknorr's Avatar
gknorr
Pretty close for what you need for a swap. You actually don't need the starter for the swap from a CVT.
You would need to add the axles and the clutch lines though.
Old Apr 17, 2014 | 03:41 AM
PBandJay's Avatar
PBandJay
I have the clutch lines. The axel shaft boots were damaged when I removed the engine, but the shafts are very cheap from Autozone.com
There are two different starter options. When I replaced mine a while back they gave me the one for the "automatic" and it didn't fit. It has a different nose cone.
Old Apr 17, 2014 | 06:24 AM
gknorr's Avatar
gknorr
Yup, the automatic on the S and the manual on the base use a different starter, but the 6-speed getrag and CVT use the same one.
Good opportunity to revive a MINI with a busted CVT...hopefully someone takes it.
Old Apr 18, 2014 | 11:04 AM
MINISPNKY's Avatar
MINISPNKY
How many miles are on the tranny?
Old Apr 28, 2014 | 09:24 AM
SuperSport1966's Avatar
SuperSport1966
Where are you located?
Old Apr 28, 2014 | 01:18 PM
PBandJay's Avatar
PBandJay
The Parts are in Rhode Island
Old Apr 28, 2014 | 02:43 PM
SuperSport1966
Thank you for your reply. I was hoping you were close to consider a local pickup
Old Apr 29, 2014 | 06:53 PM
onlycoopers's Avatar
onlycoopers
PM sent
Witsticka
16
Jun 23, 2021 07:34 AM
Sc00terbum
Sep 11, 2015 07:17 AM
Gremothra
Sep 9, 2015 08:42 PM
tylewis
Sep 6, 2015 07:36 PM
