R52 Convertible top - one side not unlatching
Old Apr 10, 2014 | 05:39 PM
ericscottf's Avatar
ericscottf
Hi all,
I've got a 2005 convertible, one side won't unlatch (sunroof works fine). Dealer said the cables stretched, and I need an entire new everything-they-could-think-of-that-day.
Before I start digging around inside it with my bentley manual, does anyone have any tips/guides?
Thanks!
Old Apr 30, 2014 | 12:55 PM
too cool blue!'s Avatar
too cool blue!
Sounds like what happened today to my 2005 too...right side is not unlatching. I will try to find some parts to oil. Please post how you get yours fixed.
Old May 2, 2014 | 08:04 AM
Check out this thread on the front latches which are moved by the sunroof position siding back on the cable set. Inspect the front latches and the cables. If the cables break on one side the sunroof only pulls back on one side. If its the latches them self and not the cables set, then the sunroof goes back all the way even and the latch does not dis-engage. There is pics in the thread of how the top looks and hardware.
https://www.northamericanmotoring.co...o-go-down.html
#14 Cables set with those front sliders. Part # 54347174761
http://www.ecstuning.com/Search/SiteSearch/54347174761/
#18 Convertible Top Front Linkage - Pair " Front latches " Part # 54347174763
http://www.ecstuning.com/Search/SiteSearch/54347174763/
Those parts above are only sold in pairs , a left and a right side. Those parts need to slide easily , check for broken and damaged parts.
Old Apr 10, 2022 | 08:07 AM
irrigation@me.com's Avatar
irrigation@me.com
how do you even replace these. i’m in this predicament.
Old Apr 10, 2022 | 05:31 PM
ChiefM's Avatar
ChiefM
Check your thead, I posted YouTube videos to help you out
Old Apr 20, 2022 | 10:27 AM
Yep^^ all linked above.
Old May 15, 2022 | 11:08 AM
Dorsetgem's Avatar
Dorsetgem
Extremely tight sunroof mechanism
Hi All
Great site, I have just read quite a few threads on this forum but have not found my problem. I purchased a R52 Cooper S with the sunroof inoperative in the winter and have been waiting for the weather to improve before I attempted a repair.
When using the open button the motor span but no movement of the sunroof so I ordered a set of cables from a seller on eBay (used). My car is a 54 plate (2004) so my understanding is that they are slightly different from the later years with additional locking pins.
I followed the 4 part You Tube upload kindly put on by a member here, and got very stuck at moving the sunroof back to release the fabric hood. The mech seemed jammed (both cables had snapped).
I ended up drilling out the bolts which hold the locking mech in order to move the rail and they were very very stiff which is what I think caused both cables to snap. I installed the new cables & mech and they are incredibly hard to slide up and down the rails.
How easy should the mech slide as I do not want to damage the replacement cables, and would anyone know why both mechanisms are so tight. I have cleaned and greased them, I started cleaning them with 800 grit wet and dry which has helped a bit but they still require quite a bit of force to slide.
I am hoping that the replacement cables & mechanisms are correct as they came from a 2004 car.
Thanks in advance
Old May 16, 2022 | 07:34 AM
If the cables are used, you have to make sure they are not stretched or damaged on the coil of the cord. I had one replaced new and its been fine ever since.
Early cables their is a design changed latch function, so make sure they match.
Old May 16, 2022 | 10:17 AM
Dorsetgem's Avatar
Dorsetgem
Thanks for reply
The tightness is not in the cables though, it's the mechanism sliding on the rails which is the problem. Once the mech is out the cables come out quite easily.
Old May 16, 2022 | 01:29 PM
Thats because the rails that it slides in a damage/not greased or the used cables front dont have the little rubber buffers or are damaged/not greased. I would inspect the ones you got.
New ones, all you have to do if clean and grease/inspect the main rails it slides in. Other then that its a bad or striped out gear on the motor. Check those gears. Also check the winding on the cables as they can get ground in one place which then stops the sliding.
Old May 16, 2022 | 01:50 PM
Dorsetgem's Avatar
Dorsetgem
Once again, many thanks. I take it that the mechanism (the carriage which slides front to rear) are all the same dimensions for the R52's then ? I might end up purchasing a new set from you if I cannot get this to glide adequately. What type of tension is the sliding mechanism under, is it an easy push pull as it takes one hand to push whilst holding the frame to get leverage to move the mech, I am taking it that is much too tight ?
Regards
Glen
Old May 16, 2022 | 02:11 PM
Yep, same, its the same tension that a sunroof cable would have on normal sunroof car.
Old May 16, 2022 | 02:18 PM
Dorsetgem's Avatar
Dorsetgem
Sorry for being foolish, when you say yep, is that to it being fairly tight or loose (I have no experience of any other sunroofs sorry)
Thanks again
Glen
Old May 17, 2022 | 06:14 AM
Tight. no problem. Tension will be tight.
Old May 17, 2022 | 01:09 PM
Dorsetgem's Avatar
Dorsetgem
Thanks once again. I have ordered some sunroof grease and will try again at the weekend.
Regards
Glen
Old May 18, 2022 | 07:11 AM
Welcome.
AutoMutt
May 11, 2017 12:35 PM
jgaspar
Aug 28, 2012 09:17 PM
blrae
Mar 8, 2012 06:12 AM
tennisjane
Aug 24, 2011 09:32 AM
