R56 Cold Engine Sound Lasting Into Warm-Engine Driving
Old Apr 4, 2014 | 03:06 PM
Engender's Avatar
Engender
Hello all,
You guys know that kind of extra rattle you have when you first start your R56S on a morning with temperatures below zero? It kind of sounds like something is sort of loose . . . and then after the engine warms up it goes away?
It seems like this sound is lasting into my drive, even during this warmer weather. Strangely, this sound seems to appear when I turn my wheels about 45 degrees to the left.
What could this be? I'm paranoid that it's a timing belt/chain failing. But, I don't think I hear the sound so loudly at idle as I hear in those videos on youtube.
I guess my question is, primarily, should I take it into the dealer ASAP? Thanks for any help!
Old Apr 4, 2014 | 06:10 PM
AZdsrt's Avatar
AZdsrt
Sounds like timing chain. I'd get it looked at, if it is the timing chain only bad things will happen..
Old Apr 5, 2014 | 07:28 PM
Engender's Avatar
Engender
I made an appointment for Monday. There's no way the timing chain is going to snap within 48 hours, right? Right?
Old Apr 6, 2014 | 12:20 PM
blakeslee_a's Avatar
blakeslee_a
I thought the same thing next thing I knew I was calling a tow truck.. If possible I wouldn't drive it
Old Apr 6, 2014 | 01:29 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
If the place you are bringing it to isn't far you should be fine.. But towing it is your best option. If its the timing chain issue that is something you want fixed right away. Good luck!
Old Apr 6, 2014 | 06:58 PM
zrickety's Avatar
zrickety
Your car should be covered by the 'campaign.' I was paranoid mine would blow up too, but I made it to the dealer for the fix.
Old Apr 7, 2014 | 07:56 PM
Engender's Avatar
Engender
Turns out it was just that my oil was 3/4 of a quart low. Additionally, my service advisor told me that I already had the updated timing chain tensioner covered by the campaign.
Another service advisor advised me to check my oil every 1,000 to 2,000 miles. Further, this other service advisor (who is not my normal SA but was standing there when I asked my SA about the updated timing chain tensioner) said that many of the problems that are attributed to the timing chain failures are in fact consequences of being low on oil.
From my reading of posts related to the timing chain, there does seem to be some sort of relationship between oil and the timing chain, although I don't fully understand what that relationship is.
I'm relieved that I only had to pay for an oil change! Check your oil!!
Old Apr 8, 2014 | 05:56 AM
zrickety's Avatar
zrickety
The tensioner is oil fed, so when pressure drops the chain is not as tight. I wonder if you were more than a quart low. Just be aware that the plastic guides can also break, so the rattle may come back even with full oil. I found out the updated timing set is only $100, but special tools required.
Old Apr 8, 2014 | 12:13 PM
Engender's Avatar
Engender
Good to know. Would slackness in the tensioner have anything to do with the fact that I appear to be loosing oil? Every time my service light comes on, I take it in within three weeks . . . so I think I've been pretty rigorous when it comes to maintenance. When I first got the car, I paid for additional oil changes in between the factory recommend ones for the first 10,000 miles or so.
How many quarts does the MINI hold? Also, this is probably a question I should have asked my service advisor, but do you know what kind of oil I should use to top off if necessary? That is, I know there are different "weights," but is there a recommended brand? I hesitated to ask my service advisor to avoid getting sold a bottle of MINI oil.
Old Apr 9, 2014 | 10:20 AM
Slave to Felines's Avatar
Slave to Felines
Check the owner's manual. There are specific oils that meet the specs that MINI has for motor oil. There's a Mobil-1 that meets them, and evidently you can often find it at Wally World. There are others as well--the owner's manual has a list for you.
Old Apr 9, 2014 | 11:23 AM
solskjaer1999's Avatar
solskjaer1999
It holds 4.4 Quarts.
Old Apr 9, 2014 | 11:24 AM
solskjaer1999
Although putting 5 quarts in isn't an issue. I do 5 quarts but 4.4 is the precise amount.
Old Apr 9, 2014 | 05:05 PM
Engender's Avatar
Engender
Great information, thanks guys!
Old Apr 9, 2014 | 07:09 PM
Bosgarage57's Avatar
Bosgarage57
Glad that's all yours was Eng, just got my mini and im experiencing a faint noise on start up. all this im hearing about broken timing chains and blown motors has me concerned.
Zettinger
Aug 25, 2015 04:04 PM
Fizzyx
Aug 14, 2015 08:24 PM
ludedude
Aug 10, 2015 07:16 PM
Miniburb
Aug 7, 2015 03:45 PM
