R52 Reversed battery cables
Old Apr 4, 2014 | 11:28 AM
Mzakowski's Avatar
Mzakowski
I reversed my battery cables when jump starting my 2005 cooper S conv.
Now it won't start I turns over just fine
Old Apr 4, 2014 | 11:31 AM
ZippyNH's Avatar
ZippyNH
OK....
Don't want to sound like a game show host....
But can you phrase the statement as a question?!
Old Apr 4, 2014 | 11:37 AM
Mzakowski's Avatar
Mzakowski
Please help
Old Apr 4, 2014 | 11:44 AM
ZippyNH's Avatar
ZippyNH
99% chance you will need to get it towed to a shop....preferably one that knows mini's....tell them EXACTLY WHAT HAPPENED.
I would check for a blown fuse....maybe one blew to protect the computer...
But unless you are accomplished as a diy'er....and know your way around the car...that is about all you can do.
When you find out what happened and the fix(I am assuming you searched for others who did the same thing)....chime back in...maybe it will help the next person.
Old Apr 4, 2014 | 11:54 AM
Mzakowski's Avatar
Mzakowski
Yes checked all fuses and looked good tested at the jump point up by the motor an I have 13.6 volts there .
Old Apr 10, 2014 | 07:34 PM
MyFastMini's Avatar
MyFastMini
R53 jump start problem
Perhaps Waylen could offer his thoughts, thats who I would go to if he were still in Indiana. Now I just call him, check him out at www.waymotorworks
Old Apr 11, 2014 | 06:48 PM
MyFastMini's Avatar
MyFastMini
expert advice
Bump for advice from those who know.
Old Apr 12, 2014 | 01:40 AM
RockAZ's Avatar
RockAZ
One thing you might try before taking it the shop is to disconnect both battery terminals for a half hour. Use that time to look at every fuse, including the fuseable link on the positive battery cable. Once reconnected you may find it starts but the radio won't come on. There may be some other failures, but take it to a good shop if everything is not ok.
I assume from your comment that the starter motor does spin up when you try to start it?
minimofo
Dec 26, 2015 12:03 PM
MINI Stupor
Oct 1, 2015 11:36 AM
jennster
Sep 28, 2015 06:19 PM
ericf1993
Sep 26, 2015 03:58 PM
rt808
Sep 25, 2015 01:59 PM
