Working on brakes
Old Mar 23, 2014 | 06:51 PM
kj6epl's Avatar
kj6epl
Working on brakes
One of the rear brakes on my R56 has started squealing, so I want to take the caliper off to lube the pins and apply anti-squeak compound to the pads. No pad wear warning light, and a quick visual inspection seems to indicate that the pads have plenty of life left. Should be pretty straight forward but...
Now here's the question: the service manual says the the caliper bolts have self-locking features and should not be reused. Is this true? I've never heard of self-locking bolts on brakes before, nor have I heard a mechanic hint or warn that some cars do. Any advice?
Old Mar 23, 2014 | 07:29 PM
ljmattox's Avatar
ljmattox
Just a few threads of what looked like blue Loctite on mine. I reapplied some and reused them. Nothing seemed unusual, pretty typical of other brakes I've serviced.
Old Mar 24, 2014 | 07:24 AM
Mini2na's Avatar
Mini2na
I don't think I've heard of anyone buying new bolts for a brake job on the MINI. Blue Loctite for me too.
Old Mar 24, 2014 | 06:35 PM
kj6epl's Avatar
kj6epl
Ok, thanks for the info.
Old Mar 25, 2014 | 06:05 AM
v10climber's Avatar
v10climber
There are a bunch of bolts on the mini that are supposedly not reusable. I've reused almost all of them. Nothing has fallen off yet.
There are a few bolts on the mini that are TTY that I've replaced but those are specifically called out with torque specs like 43lbs/ft + 90 degrees or something like that. The driver side motor mount I believe uses TTY bolts.
Old Mar 26, 2014 | 08:52 AM
ashchuckton's Avatar
ashchuckton
Loctite 242 is your friend.....
Old Mar 26, 2014 | 10:11 AM
Angib's Avatar
Angib
If you look at the (new) caliper bolts in this photo, you'll see the band of threadlock that comes on them. BMW include replacement bolts with their brake discs so that mechanics don't need to use (liquid) threadlock. It's the threadlock band that is single-use, not the bolt itself, as far as I am concerned.
Old Mar 26, 2014 | 03:31 PM
ashchuckton
Makes sense, thanks for that.
W0TM8
Dec 19, 2019 07:50 AM
minimofo
Dec 26, 2015 11:45 AM
thebordella
Aug 31, 2015 01:37 PM
