Drivetrain Replacing Rear Endlinks
Old Mar 1, 2014 | 10:29 AM
wzabrouski's Avatar
wzabrouski
Started to replace the endlinks on y CM and the set up is different on the CM than the R56. Has anyone been able to access the bolt in the trailing arm without taking the rotor off?
Old Mar 1, 2014 | 12:28 PM
wzabrouski's Avatar
wzabrouski
Figured it out. You have to take the caliper off and loosen the bolt for the rotor and move the rotor slightly. This gives you the clearance. The other issue is the new endless is look too long at their shortest.
Attached Thumbnails Replacing Rear Endlinks-image-2320791663.jpg   Replacing Rear Endlinks-image-789451204.jpg   Replacing Rear Endlinks-image-2563874104.jpg
Old Mar 1, 2014 | 01:00 PM
bmwr606's Avatar
bmwr606
gotta ask ... why are you changing them?
Old Mar 1, 2014 | 05:02 PM
wzabrouski's Avatar
wzabrouski
Been a while since I swapped these out on my R53. These are adjustable to get rid of preload on the sway bars.
boostedhaze
Jan 2, 2018 07:26 PM
squawSkiBum
Oct 2, 2015 09:21 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
Minibeagle
Aug 13, 2015 10:00 AM
