Suspension Koni FSD Install help
Old Mar 1, 2014 | 08:07 AM
BC_Rob's Avatar
BC_Rob
Hi
I'm installing FSD's on my 2007 MCS and I'm having some difficulty installing the OEM bolt on top of the front strut. Does the OEM bolt fit? The koni thread pattern looks finer than the threads on my OEM sport shocks.
Rob
Old Mar 1, 2014 | 08:27 AM
Fly'n Brick's Avatar
Fly'n Brick
I took mine and a sway bar into the friendly local tire shop for installation. They had me in and out in a couple of hours so I can't say for sure but did you look in the packaging real good to see did KONI provide the appropriate hardware? I can't imagine that they wouldn't.
Old Mar 1, 2014 | 08:32 AM
BC_Rob's Avatar
BC_Rob
I bought them slightly used on this site and they weren't included. I'm sure they are inexpensive to purchase.
Old Mar 1, 2014 | 06:53 PM
BC_Rob's Avatar
BC_Rob
Install complete. Initial thoughts are MUCH better ride wrt smoothing out the bumps.
Old Mar 2, 2014 | 01:02 AM
hamptup's Avatar
hamptup
Did you figure out what was going on with the bolt? Did you encounter any other problems with the install? I have the factory sport suspension and I'm hoping the FSD will smooth out the harsh ride a little.
Old Mar 2, 2014 | 05:57 AM
BC_Rob's Avatar
BC_Rob
The front struts do require a different bolt than the stock one. Apparently, the new shocks come with a 12mm bolt with a 1.25 thread pitch. Install went fine other than that. Good luck with it!
Rob
Old Mar 14, 2014 | 08:02 PM
BC_Rob's Avatar
BC_Rob
The FSD's really transform the ride compared to the OEM Sport Suspension. What I don't like is the fact that the wheel gap is now slightly larger!
Rob
Old Mar 14, 2014 | 11:23 PM
hamptup's Avatar
hamptup
Rob
Thanks for the update! I just remounted the 18"s with a low profile tire so I'm now looking forward to installing the FSD's so my wife will be happy again.
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
Emnotek
Aug 13, 2015 05:47 PM
