R56 Mobil1 or Mobil3000?
for me the answer is easy
I find 1 on the shelf at the store - but I need to look around for it. It is the ONE time I'll go into WallyWorld, otherwise I avoid the place.
and can't remember ever seeing 3000
is there a cost difference?
Don't know where you are located.
I think the Mobile 1 3000 is here in different versions OP is talking about ?: Don't remember seeing it here in the US.
http://www.mobil.com/UK-English-LCW/...a-fe-5w30.aspx
Look for meeting BMW LL 01 and ACEA A3/B3 & API Service SL/CF .
The Mobile 1 0W40 we carry is the one marked European Car formula.
http://www.ecstuning.com/Search/SiteSearch/ES2575992/
P.S.
Just do you understand...
BMW/mini reccomends different oils specs for some parts of the world...
Namely North America and locations where fuel has a ethanol component.... It makes more moisture when burnt....result in the need for a oil formulated differently...Thst is why euro oils for the new spec says they are ok for diseal motors...but acpoor choice for gasoline motors that can dilute oils with moisture more easily.....
Both meet BMW LL spec, and the 3000 appears to also cater to diesel products. A quick seach on BITOG shows that it is a lower tier oil compared to the 1.
http://www.bobistheoilguy.com/forums...Number=2830455
Personally I'll stick to using Mobil 1 0w-40 euro car formula which is only $25 for a 5 qt. jug (if you can find it) at your local Wally World.
lolol regardless! if you're looking at oils you might as well consider all options
after reading some white paper reports I'd only use Mobil 1 in my lawnmower. They made some changes over the last few years and quaker state Q is far better than it. I just buy the MINI oil at local dealership for $7 a quart.
oeklm
Feb 17, 2016 01:00 PM
GPToyz
Nov 27, 2014 12:10 AM
