Drivetrain ATI Damper Titanium Bolts
Old Feb 24, 2014 | 04:51 PM
RA082324's Avatar
RA082324
I have 2 parts to this post.
Part 1: Numbers
Has anybody had any experience with these?
At $80 for the set, I'm curious if there are any factual numbers to be had as far as weight difference between the standard bolts, and if possible (math for the math people) how much lighter/faster would the damper be, if at all.
I know from a bit of science I learned about rotational mass and unsprung weight, that, the most significant weight loss/addition, in regards to power, is had at the outermost section of the rotating object.
Being that these bolts are on the inner 50% of the damper itself, how much affect will they have?
I am interested to learn more. They seem like a great idea for an upgrade to the ATI product. Best dampening, with lighter weight. If anyone gets their hands on these, please, weigh them before you install them, and weigh the standard bolts coming out. If there are any additional tests you can perform, post the data here.
Part 2: Install
I am also curious, can these bolts be installed without removing the damper... say if you were to fully remove and install 1 at a time... or will it be required release the tension, pull the damper, remove the standard bolts, replace with titanium, reinstall damper with new crank bolt... etc?
Thanks in advance for any info.
Old Feb 24, 2014 | 04:56 PM
ACallahan's Avatar
ACallahan
Personally I think not worth dropping $80 on them. I don't think there would be any difference worth noting. Again just my personal feeling on them.
Old Feb 24, 2014 | 09:17 PM
RA082324's Avatar
RA082324
my thoughts as well. hopefully somebody catches this and can provide some numbers anyway.
Old Feb 25, 2014 | 06:42 AM
soccerbummer1104's Avatar
soccerbummer1104
If someone sends me the size of bolt and number of bolts I can calculate it up.
Old Feb 25, 2014 | 06:47 AM
Saltysalt's Avatar
Saltysalt
easy to calculate, noticable differece? depends on the amount of hardware changed
for racing, every bit counts, plus no chance of rust
idea for weight savings: 1 cubic inch of material
stainless steel hardware will weigh: 4.32oz-4.624oz
titanium:2.601oz
so its about 40% - 44% lighter
size of the bolts would be able to tell you the actual weight savings
Old Feb 25, 2014 | 07:19 AM
RA082324's Avatar
RA082324
nice. good info so far.
Old Dec 24, 2014 | 10:56 AM
ncsurfer's Avatar
ncsurfer
Just replaced my sc pulley and installed titanium bolts, got them from wmw, was about $48, also replaced my crank pulley with a ATI version, talking with my buddy who does high end motor cycling work, it does make a difference.....knowing that it has stronger and lighter bolts in place makes me feel better, also notice quicker revs
Old Dec 24, 2014 | 07:04 PM
ashchuckton's Avatar
ashchuckton
Oh my, you feel quicker revs with those titanium bolts. Man the placebo effect is very strong with those.
Old Dec 24, 2014 | 09:25 PM
cerenkov's Avatar
cerenkov
Are they actually stronger or just lighter? I know that on Way's website it says that they are "super strong".
Old Dec 31, 2014 | 07:37 AM
nkfry's Avatar
nkfry
The biggest advantage to the titanium bolts are that they are stronger than the steel hardware, as well as they are reusable, as opposed to the steel hardware that looses it's ability to take torque.
If you are installing the damper once and not rebuilding it the steel hardware will work fine, the titanium hardware is more marketed to those who are rebuilding their dampers multiple times during its life.
That said, there is no downsides to you buying and installing them.
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 31, 2014 | 08:10 AM
Saltysalt's Avatar
Saltysalt
technically stainless steel is stronger than titanium, but strength/weight Ti wins. which makes it ideal. Since Ti is more ductile than steel, it will hold the torque better (easier to deform) could you actually test the difference in everyday? No since they are engineered factors away from failure. like I posted above, Ti is about 40% lighter than steel, and if the total weight of the bolts is 10oz, then you have 6oz in titanium bolts near the center of rotation..... is the a difference? yes technically there is. can you feel it? no, is it measurable? yes but other factors will make more of a difference. im glad that you are enjoying it, and you have the bragging right that you have Titanium hardware.
Old Jan 1, 2015 | 07:43 AM
ncsurfer's Avatar
ncsurfer
Titanium bolts
No, quicker revs with 16% pulley with ati crank pulley, just piece of mind with titanium bolts....
boholio
Nov 9, 2015 03:50 PM
Fordgt4
Oct 10, 2015 10:42 AM
Vaderm34
Sep 27, 2015 09:25 PM
VanisleRyan
Sep 13, 2015 09:55 PM
