R56 hatch problems
Old Feb 16, 2014 | 04:07 PM
jeeprus's Avatar
jeeprus
hatch problems
my 07 cooper hatch is locked it will not release tried manual pull will not work...can anyone tell me how to remove trim to access latch with hatch in closed position....Thanks
Old Feb 18, 2014 | 06:08 AM
Here in the manual release link, just to make sure you have the right cable.
https://www.northamericanmotoring.co...k-release.html
#1 is the lock itself and looking at it o the left hand side, you can see the white nylon little eyelet , that's the manual trigger release. If the lock is bad electrically you have to replace when you can manually trigger the lock , then open the hatch. Have someone help you press on the hatch a little while you mess with the lock.
Trunk Lid Lock Part # 51242754528
http://www.ecstuning.com/Search/SiteSearch/51242754528/
The cables connects to the top of the lock, its might have popped off and is located under the bottom panel .
#3 in the rear trim panel which the lock is under to get access to it. You will have to pry it up, as it snaps in on the op and then has expanding plastic rivet on the bottom.
Toolman
Jan 20, 2016 06:50 AM
nismo4life
Nov 4, 2015 09:18 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
automan21
Aug 12, 2015 03:36 PM
