O2 sensor problem
Old Feb 13, 2014 | 08:40 AM
Rub0's Avatar
Rub0
O2 sensor problem
Hello guys I have a 2011 mini cooper S and my 02 sensor went bad. When i got it checked out the error code was P2097 which the mechanic told me it was the O2 sensor by the catalytic converter. Does anyone know where i can get the sensor for cheap. I called the dealer they said the part alone is about 300$
Old Feb 13, 2014 | 08:54 AM
Don't know if you are out of warranty already. But here is the parts for the 2011+ R56 MINI Cooper S N18 engine . There is one before the Catalytic and one after the Catalytic, the code for "P2097" looks like after, post Cat.
After the P code it should say on the scan, bank 1 or bank 2. Bank 1 is the upper pre cat, bank two is the lower post cat..
#1 Oxygen Sensor Part # 11787576673 Pre Cat
http://www.ecstuning.com/Search/SiteSearch/ES254259__ES2587942/
OR
#2 Oxygen Sensor Part # 11787548961 Post Cat.
http://www.ecstuning.com/Search/SiteSearch/11787548961/
Make sure if you use a tool not to use one that will damage the neck on the head of the sensor. I use one like this so you wont damage it. Its a side connect version. 3/8's ratchet extension.
http://www.ecstuning.com/Search/SiteSearch/UN1204250/
Old Feb 13, 2014 | 01:06 PM
Rub0's Avatar
Rub0
thank you very much that helped a lot I think he said it was bank 2 but i can go back let him scan it again
Old Feb 13, 2014 | 01:11 PM
Welcome. Just check and make sure which one you need via the scan. Then you will be good to go.
Kimolaoha
Jul 5, 2023 01:04 PM
alistaircookie
Oct 8, 2015 10:52 AM
HaveATank
Sep 4, 2015 08:04 AM
Marktheman
Aug 23, 2015 11:45 AM
massmini03
Aug 12, 2015 11:19 AM
