Drivetrain Help! Turbo is acting funny
Dear Minis,
My beloved 2009 MCS is letting me down hard right now
. When accelerating hard sometimes the turbo spins up and stay strong, on the same drive, next stoplight, the turbo pulls to perhaps 1500-3000 rpm, (varies even in same gear) and then completely stops providing any boost. No codes are being thrown. I've gone up to about 11 miles where I get no boost above ~2000rpm.
I'm not sure where to begin troubleshooting since i'm not getting any codes, perhaps I need to remove the tune and see if that fixes the issue? I don't know if this helps any but it sounds like the re-circ valve is actuating at the rpm where I lose boost, perhaps this valve is malfunctioning but since its aftermarket the codes don't get thrown???
This car has drivetrain mods:
-NM Engineering Intake & Boost Tubes
-Alta Re-Circ Valve
-ALTA FMIC
-Catless DP
-Alta 3" Exhaust
-Stage 2 AP Tune
Anyone experienced this or similar issue before or know what could be causing this? Thought or suggestions would be sincerely appreciated...Thanks
. When accelerating hard sometimes the turbo spins up and stay strong, on the same drive, next stoplight, the turbo pulls to perhaps 1500-3000 rpm, (varies even in same gear) and then completely stops providing any boost. No codes are being thrown. I've gone up to about 11 miles where I get no boost above ~2000rpm. I'm not sure where to begin troubleshooting since i'm not getting any codes, perhaps I need to remove the tune and see if that fixes the issue? I don't know if this helps any but it sounds like the re-circ valve is actuating at the rpm where I lose boost, perhaps this valve is malfunctioning but since its aftermarket the codes don't get thrown???
-Alta Re-Circ Valve
-ALTA FMIC
-Catless DP
-Alta 3" Exhaust
-Stage 2 AP Tune
It's pretty common to throw codes of some type if you are having boost problems. As you said, maybe the tune is masking the code.
You can check a few things regardless. Use a handheld vacuum pump and check the wastegate. I don't recall the correct vaccum level but you can verify if the wastegate holds.
You can also check the vacuum lines for weakness or leaks.
Good luck.
Good luck.
EVMini
Sep 28, 2015 10:20 AM
