Drivetrain Help! Turbo is acting funny
Old Feb 8, 2014 | 04:54 PM
bendari500's Avatar
bendari500
Dear Minis,
My beloved 2009 MCS is letting me down hard right now. When accelerating hard sometimes the turbo spins up and stay strong, on the same drive, next stoplight, the turbo pulls to perhaps 1500-3000 rpm, (varies even in same gear) and then completely stops providing any boost. No codes are being thrown. I've gone up to about 11 miles where I get no boost above ~2000rpm.
I'm not sure where to begin troubleshooting since i'm not getting any codes, perhaps I need to remove the tune and see if that fixes the issue? I don't know if this helps any but it sounds like the re-circ valve is actuating at the rpm where I lose boost, perhaps this valve is malfunctioning but since its aftermarket the codes don't get thrown???
This car has drivetrain mods:
-NM Engineering Intake & Boost Tubes
-Alta Re-Circ Valve
-ALTA FMIC
-Catless DP
-Alta 3" Exhaust
-Stage 2 AP Tune
Anyone experienced this or similar issue before or know what could be causing this? Thought or suggestions would be sincerely appreciated...Thanks
Old Feb 8, 2014 | 05:56 PM
pidge1114's Avatar
pidge1114
Too many variables to determine what it could be. Any one of your mods could be the culprit.
Old Feb 8, 2014 | 06:21 PM
05r50's Avatar
05r50
It's pretty common to throw codes of some type if you are having boost problems. As you said, maybe the tune is masking the code.
You can check a few things regardless. Use a handheld vacuum pump and check the wastegate. I don't recall the correct vaccum level but you can verify if the wastegate holds.
You can also check the vacuum lines for weakness or leaks.
Good luck.
Old Feb 8, 2014 | 07:09 PM
MINIdave's Avatar
MINIdave
Pull the intake boot off, stick your finger in and try to move the turbine wheel. If there's play in it the turbo is bad and needs to be replaced, if no play the problem is elsewhere....
Old Feb 10, 2014 | 08:02 AM
bendari500's Avatar
bendari500
Thanks for the quick replies
The code threw this morning on the way to work
P28b1 Bypass Valve Signal
Old Feb 10, 2014 | 01:50 PM
johntotah94's Avatar
johntotah94
Probably Alta's fault
Old Feb 10, 2014 | 03:42 PM
v10climber's Avatar
v10climber
Do you have a boost gauge? Do you know you're actually not making boost?
Sent from my DROID RAZR HD using NAMotoring
NYMADMINI
Dec 14, 2016 02:33 PM
honderpilot
Oct 11, 2015 06:35 AM
Fordgt4
Oct 10, 2015 10:42 AM
TifosinDel
Sep 28, 2015 10:45 AM
EVMini
Sep 28, 2015 10:20 AM
