R56 Will a F56 steering wheel work with a R56
Old Feb 2, 2014 | 07:41 AM
mkiiivr's Avatar
mkiiivr
Not sure if anyone would know yet but thought I would throw the idea out there. Can you put a F56 steering wheel with airbag work/fit in a R56?
I really like the look of the new steering wheel and would like to try it.
Old Feb 3, 2014 | 08:14 AM
I can tell you the F56 steering wheel will unlikely fit the R56. The Steering wheel pads and wires are a little different set up. The slip ring behind the wheel is different with the wiper stalks. The airbag is different , on top of the electronics and so on. I have been in the F56 in person.
For R56 dirrect fit upgraded sterring wheels: here are some options. If you have the three spoke wheel:
This is the JCW Leather wheel that is normal thickness but has a red stitching on the inside. Found on newer JCW's and JCW Countryman.
JCW ( normal thickness ) Steering Wheel Leather W/ Red Stitching - Manual transmission
http://www.ecstuning.com/Search/32306798801/ES2178694/
Those parts above ( on your last post ) are the JCW "Thicker" wheel in Full leather or Alcantara
http://www.ecstuning.com/Search/32300416250/ES52298/
JCW "Thicker" wheel in half Alcantara / Leather
http://www.ecstuning.com/Search/32300416251/
OR
Here is close up of the JCW GP 2 wheel, thicker in full leather w/ red stitching.
JCW GP2 Leather Steering Wheel - Red Stitching
http://www.ecstuning.com/Search/SiteSearch/32306858010/
You will need to swap out your key pads w/wires or blanks dependent on your options as well as the airbag. I would recommend if you do this yourself to make sure you disconnected the airbag to do the install as you don't want to trip the airbag light.
Old Feb 4, 2014 | 05:32 AM
mkiiivr's Avatar
mkiiivr
Thanks for all the great info!
Old Feb 4, 2014 | 05:42 AM
You are welcome.
Old Jan 15, 2016 | 07:56 PM
miniuy's Avatar
miniuy
Working on the R50.
Why not on the R56?
Surely there is a hard wiring work, as ECSTuning said.
Old Jan 18, 2016 | 06:49 AM
Nope the f56 ( gen 3 ) version will not fit the R56 ( gen 2 ) or R50 ( gen 1 ) unless you highly modify or something, The threads are different also. Lots of work, just better to get a custom wheel using that same Generation or get the JCW version of that generation.
Old Jan 19, 2016 | 06:13 PM
enoe01's Avatar
enoe01
I was wondering if anyone has added this wheel yet? ;-)
Old Jan 20, 2016 | 08:11 AM
airbag delete kit
Zettinger
Aug 25, 2015 04:04 PM
skippermini
Aug 12, 2015 10:05 PM
nomar116
Aug 12, 2015 05:24 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
