Drivetrain Bov recirc valve n18 engine problem!
Old Jan 20, 2014 | 01:52 PM
dorykiki's Avatar
dorykiki
I followed exactly every step of the installation guide
First they do not mention in the installation guide that you have to shave the electric plug for it to fit Thank you forge !
Second since I installed the BOV , I keep geeting every morning when I start the car with a cold
Engine a check engine light
Went to my mini garage and scanned the fault it showed on the scanner :
Fault code ; 28DB throttle valve actuator , closing spring check , error during spring check !
Did someone experience the same problem and
Thank you
Old Jan 21, 2014 | 01:50 AM
robbo mcs's Avatar
robbo mcs
Thank you
Are you sure you have the right forge part? It is a different kit for the N14 vs N18 engines. The plugs are different. You should not have to shave the plug?
Never had that code. I did once get the 2885 boost implausibility code when the vacuum lines were actually reconnected wrongly
Old Jan 21, 2014 | 02:37 AM
dorykiki's Avatar
dorykiki
I am quite sure it is , it says countryman n18 engine and the bov valve ref is :FMDVR60R
the intriguing part in the installation document they sent in the box is that they do not mention anything about the electric plug and how to fit it so I found out on this forum that some people had to shave some plastic to fit the plug.
Old Apr 1, 2014 | 09:54 AM
Jevans12588's Avatar
Jevans12588
Having the same problem, how much did you have to shave off and which end of the connector
Old Jun 20, 2014 | 01:07 PM
Roxspin72's Avatar
Roxspin72
N18 Owners,
I know its been awhile, just wondering how your DVs have been operating? Mine feels like all is good after installing it couple weekends ago. However, I am not totally sure what I should be hearing and or feeling. I currently hear the pronounced Pshhh sound due to my open Intake Filter. Also hearing a whistle type noise when on light throttle cruising around neighborhoods between 2-3000 RPM. Anyone else experience this with their N18's. Like I said, overall I'm happy with it. Just wanted some clarity on how to test that it is functioning correctly and performing it's task.
Thanks,,,
Old Jun 20, 2014 | 09:46 PM
luigi90210's Avatar
luigi90210
Originally Posted by Roxspin72
N18 Owners,
Thanks,,,
completely normal, just induction noise(specifically the turbo)
Old Jun 20, 2014 | 10:17 PM
Roxspin72's Avatar
Roxspin72
Old Jul 22, 2015 | 03:43 PM
tournot97's Avatar
tournot97
well at least you guts got instruction with your How ever I did not..... LOL SOOOOOO In my shop it sits......
theunlimitedone
Aug 31, 2015 08:17 PM
Zettinger
Aug 25, 2015 04:04 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
flredmini
Aug 12, 2015 06:35 PM
