Navigation & Audio Hum with RPM increase
Old May 29, 2004 | 11:37 PM
itsthedirtybird's Avatar
itsthedirtybird
I have a hum in only my right speakers with RPM increase. When the car is in neutral there is no hum. Does anyone know how to alleviate this ?
JL 300/2
Diamond Audio 5.25 inch Hex Components.
thanks
Old May 30, 2004 | 02:47 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
Sounds like the speaker is picking up engine noise, which most likely is coming from a power wire. Did you add aftermarket amp? In any case, there are several things you can try.
1. use a better insulated wire
2. re-rout the wire to avoid any power wire
3. re-ground the wire, using a better wire and/or try different location
4. use a noise isolator
Good luck!
_________________
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
