I have a hum in only my right speakers with RPM increase. When the car is in neutral there is no hum. Does anyone know how to alleviate this ?
JL 300/2 Diamond Audio 5.25 inch Hex Components. thanks |
Sounds like the speaker is picking up engine noise, which most likely is coming from a power wire. Did you add aftermarket amp? In any case, there are several things you can try.
1. use a better insulated wire 2. re-rout the wire to avoid any power wire 3. re-ground the wire, using a better wire and/or try different location 4. use a noise isolator Good luck! _________________ https://www.northamericanmotoring.co...t_L7.thumb.jpghttps://www.northamericanmotoring.co...rial.thumb.jpghttps://www.northamericanmotoring.co...de_7.thumb.jpg |
