2011 Base throwing 3 codes: P0100, P0003, P15E5
Old Jan 15, 2014 | 05:55 PM
MiniVelvet's Avatar
MiniVelvet
The CEL came on this afternoon. My OBDII scanner/trip logger shows 3 codes and the following descriptions: mass or volume air flow circuit, unknown powertrain DTC, and fuel volume regulator control circuit low.
Ran a search on NAM and pulled up a few threads with limited information to apply to my situation. Any thoughts?
For the P0100 fault code, I plan to check my K&N air intake set up to make sure that everything is tight and clean. It was installed last September and never caused any lights to come on.
For P0003, I wonder if it has anything to do with the royal purple max clean that I used some 5 tanks ago.
For P15E5, I think the engine misfired once today, not sure what part of the engine to check?
All 3 codes are detected/noted at the same time.
Old Jan 21, 2014 | 10:54 AM
MiniVelvet's Avatar
MiniVelvet
CEL went away after codes were cleared. My research shows that the problem is mostly likely with the MAF sensor. Purchased the CRC spray to clean said sensor should CEL return.
Old Jan 21, 2014 | 12:17 PM
kyoo's Avatar
kyoo
thanks for updating the thread even though no one responded
Old Jan 21, 2014 | 12:27 PM
MiniVelvet's Avatar
MiniVelvet
Haha I gotta help myself if no one is around. Having the code reader really helped reduce my anxiety. The carchip pro is somewhat outdated but still does the job.
jetmechinnc
Nov 16, 2020 06:38 AM
mellocooper
R55 :: Clubman Talk (2008+)
Jul 21, 2016 05:05 PM
HaveATank
Sep 4, 2015 08:04 AM
drum6g
Sep 1, 2015 09:09 AM
Devoman
Aug 25, 2015 10:59 AM
