R50/53 HELP: Rear Fog/Brake light Retro fit for R53 S
Old Jan 8, 2014 | 01:20 AM
James Davis's Avatar
James Davis
Hey guys, My 2006 R53 doesnt come with rear fog lamps and I just recently bought one from Outmotoring, I want to use this as an additional brake light instead but i could not find any wiring diagram anywhere on how/where to splice the wires to the tail lights. When i opened the black plug/cover for the fog light, the plug is already there, i plugged it in but i guess theres no toggle switch for it to work. My plan is to just use this existing wire and just tap it into the brake light, problem is I dont know which wire to connect it too. I would appreciate the help!
Old Jan 8, 2014 | 03:16 AM
bavmotors's Avatar
bavmotors
Id be interested in this as well, wonder if all of them have the wiring there already.
Old Jan 8, 2014 | 03:24 AM
James Davis
There are so many revisions on different year models. I was surprised seeing that plug was already there so I plugged it in and turn on lights, reverse, font foglights whatever but still doesnt work If the wire is there, its gotta be hooked up somewhere for it to work!
Old Jan 8, 2014 | 03:53 AM
Mootsdog's Avatar
Mootsdog
There used to be a kit you could buy to make this simple but the Company discontinued them. I found one on eBay. http://www.ebay.com/itm/Go-Mini-Go-G...-/330998350694
I have it in my R52s. The kit allows you to make it a brake light or a reverse light. For the reverse light you would a clear lens assembly.
Here is the link to the instructions. http://www.images.gominigo.com/instr...5-2006_blk.pdf
Hope this helps
Old Jan 8, 2014 | 04:37 AM
ZippyNH's Avatar
ZippyNH
Since the light comes from the bcm....
To make it work you would need a new toggle switch and some programming...
But if you disconnect the wiring that is in place (prevent back feeding that could dammage the bcm) you could just run a homemade harness..might even be able to skip using a relay if you use a bright led...then add a switch....
Imo, when I have debated doing this....the above kit...making it into a extra brake light makes more sense on "refresh" gen1' mini...the toggle switches are $$, and getting the RIGHT combo of lettering and number of switches is hard....and used the right way...rear fogs (early used RIGHT) are rarely used(not every time it is dark or rainy...the extra light confuses many drivers..wait for ..er..fog!!).
Old Jan 8, 2014 | 07:20 AM
minsanity's Avatar
minsanity
Locate the brake light wires by following this guide:
http://www.motoringfile.com/howto/brakelight_mod.pdf
Line it to where the fog is , add a pulsar kit & turn it into a 4th brake light!
Old Jan 8, 2014 | 07:46 AM
minibx's Avatar
minibx
Also Outmotoring has this as well http://www.outmotoring.com/add-a-bra...iring-kit.html
Old Jan 8, 2014 | 12:36 PM
James Davis
I appreciate all you guys feedback, thank you!!!
Old Jan 8, 2014 | 04:12 PM
scottie10014's Avatar
scottie10014
I just popped mine in without wiring it. Clearly won't work as a brake light, but looks good. :-)
Old Jan 8, 2014 | 07:47 PM
James Davis
Originally Posted by minibx
Thanks minibx, I also have that wiring kit when i ordered mine from Outmotoring, just doesnt have instructions on where to wire it to the taillight.
Old Jan 8, 2014 | 10:52 PM
minibx's Avatar
minibx
Call them up they may have a DIY they are very helpful
Old Jan 9, 2014 | 10:38 PM
Kdub's Avatar
Kdub
Here is DIY instruction on how to do it. You just have to get a piece of wire, a couple of splicing connectors, and optionally a diode and jump a couple wires.
I just did this mod too! but I chose to turn the third light as a reverse light. It's just a matter of choosing which wire to jump for either brake or reverse light.
And here is a pic of the result. I am super pleased with it. Initially I was going to just make it a dummy light as I really hated that ugly plastic cover. But I wanted to make it functional if possible, and after some researching I found the above webpage. The mod was super easy if your car is already prewired.
Attached Thumbnails HELP: Rear Fog/Brake light Retro fit for R53 S-photo1.jpg
Old Apr 6, 2020 | 08:17 PM
Serafin's Avatar
Serafin
Bringing this back from the dead. Anyone have a working link on where splice for rear brake lights? Thank You
Old Apr 7, 2020 | 06:56 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
you mean an extra reverse light ? If so mine has one wired in I can go take a few pics of for you if you needed.
Old Apr 7, 2020 | 07:43 AM
Serafin's Avatar
Serafin
no not a reverse light. Extra Brake light.
i did an LED for my brake light and it’s really bright even over my tinted tailights. Lol
but I’m sure it’s the same wiring right? Just tapped to the brake lights instead of the reverse light?
i do have the plug behind the cover already.
Thank You
Old Apr 7, 2020 | 08:56 AM
MiniManAdam
Community Builder
Thank You
That's what I've done when I've installed extra brake lights. Or run it off the 3rd brake light as its usually easier .
Old Apr 7, 2020 | 09:54 AM
adriancl's Avatar
adriancl
Extra brake light is linked direct to Body Computer,wire colour Black yelow,, pin 30 on C socket of body computer.
Old Apr 7, 2020 | 10:57 AM
Serafin's Avatar
Serafin
this is way over my head lol
Old Apr 7, 2020 | 11:00 AM
Serafin's Avatar
Serafin
ok. So from the existing fog lamp wires. What wire or wires do i cut or splice and where to splice it onto.
Old Apr 14, 2020 | 09:36 PM
Serafin's Avatar
Serafin
hello. Do you mind taking a pic for me please on what wires to splice? Do i cut the existing wire underneath or do i splice into it? Thank You
again it’s for 4th brake light.
ps. Will the light work with tail lights and gets brighter when i step on the brakes?
wkp1219
Nov 13, 2015 07:52 AM
Mini'mon
Aug 26, 2015 01:02 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
