08 R56 Non S to S Swap
Old Jan 5, 2014 | 06:05 PM
NovMINI's Avatar
NovMINI
I have the part car.
Did the direct motor/ecu swap
Swapped the battery / fuel pump
The swap was fast and easy.. took less than 12 hours to take both out and put the s in with fuse box and DME
HOWEVER
The car will crank but will not fire...
Would anyone know the problem or has done this swap before.
I have the CAS out and ready to swap but i don't want to pull my car apart more if i dont have to... essentially getting fuel but no spark and all the wiring checks out.
I know many have said its useless to do this swap but the motor on my non s blew and I found a salvaged S that ran but had severe chassis damage for under 5k including shipping.
Any help will be appreciated.
temp cell: 8437434907
if anyone is willing to help over the phone
Old Jan 5, 2014 | 06:17 PM
NovMINI's Avatar
NovMINI
Pics of the swap
Attached Thumbnails 08 R56 Non S to  S Swap-forumrunner_20140105_211549.jpg   08 R56 Non S to  S Swap-forumrunner_20140105_211603.jpg   08 R56 Non S to  S Swap-forumrunner_20140105_211645.jpg
Old Jan 5, 2014 | 06:44 PM
S&CLC's Avatar
S&CLC
Old Jan 5, 2014 | 06:54 PM
NovMINI's Avatar
NovMINI
Thanks for the response...I have everything out of the s, trying the body control module module now... If this works I'll be done! If not I have all the parts and computers to do it
Old Jan 5, 2014 | 07:04 PM
NovMINI's Avatar
NovMINI
Didnt work swapping cas now
Old Jan 5, 2014 | 07:27 PM
Husam Hammadi's Avatar
Husam Hammadi
As far as i know, on modern cars you have to swap all computers from the donor car to the new car, including the key fob and some other small stuff for the car to work properly..
I know because i swapped a '10 malibu.. You need everything swapped!
Old Jan 5, 2014 | 07:37 PM
Ian Landesman's Avatar
Ian Landesman
Call up the famous indie mechanics. I don't think they'd charge too much to consult with you to help diagnose the problem. A lay guy like me has nothing more to add unfortunately. =( Best of luck!
Old Jan 5, 2014 | 07:57 PM
NovMINI's Avatar
NovMINI
Husam, I'm just about to have all the computers behind the dash swapped... Thank you for the response hopefully I'll be done here soon and won't have to do something ridiculous like a main harness swap... Switch I'm already prepared to do.
Old Jan 5, 2014 | 07:59 PM
NovMINI's Avatar
NovMINI
Thanks man, do you know their numbers? Unfortunately I don't know who you're referring to lol
Old Jan 5, 2014 | 08:09 PM
3lusive's Avatar
3lusive
Try looking here for shops around your area: http://www.minirepairshops.com/
sometimes people post reviews of the shops, otherwise use it as a starting point to find on yelp or google reviews.
Good luck!
Old Jan 5, 2014 | 08:20 PM
NovMINI's Avatar
NovMINI
Good luck!
Okay thanks, good backup plan I guess, I'm almost done really... I just need it to start... Turns over and gives me tons of info except why it won't start
Hooked my computer up to it and that got me no where... Need a BMW computer to do anything
Old Jan 5, 2014 | 08:32 PM
Capn How's Avatar
Capn How
You will def need the CAS, possibly the tach as well. Not sure about the other ecu's.
Old Jan 5, 2014 | 08:43 PM
Ian Landesman
The only one I've had personal experience with is Wayland of Way Motor Works. 770-234-9965.
I'd also try Helix. 267 335 4337. I don't have any personal experience with them (they are across the country from me), but they chime in a lot in the forums to help people out.
If they can't help you, I'd at least think they'd be able to point you in the right direction.
Old Jan 5, 2014 | 09:04 PM
NovMINI's Avatar
NovMINI
I did it! Swap from non s to s complete! Just needed to swap the key unit(CAS) and its works!
Possibly only non s to s r56 in the US? The world?
NovMINI's Avatar
NovMINI
Thanks for the responses anyway! Love this forum!
Old Jan 5, 2014 | 09:24 PM
vetsvette's Avatar
vetsvette
Moderator
Outstanding! Way to go man. You are now the new expert in Justa to S swap.
Old Jan 5, 2014 | 09:27 PM
NovMINI's Avatar
NovMINI
That is truly humbling title thank you!
Check me out on fb, Noveed Motevalli for all the pics and details and I'll post it up on youtube too.
Old Jan 6, 2014 | 04:42 AM
S&CLC's Avatar
S&CLC
CONGRATULATIONS! Awesome. Too cool. You are a MINI revolutionary.
I hope you don't mind if I contact you for information this fall (or the next spring) when I do the same thing to my MINI...
Keep us updated on your test runs and additional modifications...
Old Jan 6, 2014 | 07:19 AM
zrickety's Avatar
zrickety
Nice job! I don't know how much the value changes, but you may want to tell your insurance co.
Old Jan 6, 2014 | 10:00 AM
Slave to Felines's Avatar
Slave to Felines
It would be really, really cool if you did a write-up on this with pics and everything....
Old Jan 6, 2014 | 10:35 AM
NovMINI's Avatar
NovMINI
Ill get what I can up sure thing, it is honestly much easier than it sounds, whole thing took about 20 hours. I didn't need any special tools or computers and pulling the engines took just 2 to 3 hours per motor.
But yeah I'll do a write up as soon as I get the chance!
Old Jan 6, 2014 | 10:39 AM
NovMINI's Avatar
NovMINI
Of course, I'm willing to help anyone who wants it, I'm in Indiana right now with just over a foot of snow I'm assuming(-14 out so I'm not even going out)... And I'm moving to Tennessee this weekend so I'll get what I can up here asap.
And Thank you!
I really hope people realize now that anything is possible even on a budget... I didn't go over 5k on this whole build btw
Old Jan 6, 2014 | 10:42 AM
NovMINI's Avatar
NovMINI
Don't tell anyone... But the chassis Vin for the non s isn't changed so the insurance doesn't need to know anything about the engine under the hood, still the "same" car just with an engine that isn't blown up.
Not lying to the insurance company just not telling the whole truth... Ha
Old Jan 6, 2014 | 10:53 AM
NovMINI's Avatar
NovMINI
Ended up being just the CAS... That wasn't too bad to pull but is was time consuming taking the dash apart and putting it back together.
Old Jan 12, 2014 | 04:49 AM
zrickety's Avatar
zrickety
5k to build an S is a bargain, I'll have to keep my eyes peeled for deals like that.
