Less dust brake pads instead of the OEMs
Old Jan 4, 2014 | 02:03 PM
BXR's Avatar
BXR
I'm looking for a less dust break pads instead of the OEMs.
It should support the brake sensors as well, better or same braking capabilities as the OEMs.
Any recommendations?
Old Jan 4, 2014 | 02:20 PM
ashchuckton's Avatar
ashchuckton
Understand that all brake pads have dust. The ceramics dust is much lighter in color & amount.
You will lose some of the initial bite of the oem pad, but for me it is worth the trade off. In every other way they are superior to the oem pad.
I've used Hawk ceramics & Akebono ceramics. I recommend both.
Old Jan 4, 2014 | 02:35 PM
phoxx47's Avatar
phoxx47
+1 Went with Akebono's that I got from Way Motor Works. Performs similar to stock, low dust, sensors work great.
Old Jan 4, 2014 | 03:09 PM
BXR's Avatar
BXR
What does it mean "initial bite"?
Initial bite at the first time or on every ride?
Is it noticeable in an everyday use?
Old Jan 4, 2014 | 05:40 PM
george_talbot's Avatar
george_talbot
Performance friction pads have minimal dust.
Old Jan 4, 2014 | 06:04 PM
JR2012IBB's Avatar
JR2012IBB
I changed to Hawk HPS pads when I got the car home, back in 2012. I have used the Hawk HPS pads on other vehicles over the years and find they are a great pad for good brake feel and reduced dusting. I would recommend them if your interested in less dust. They are not 'dustless' but certainly are a lot less annoying in that regard than the OEM pads.
Old Jan 4, 2014 | 09:21 PM
3lusive's Avatar
3lusive
EBC Green which I have on the MINI right now are very low dust, since I replaced the OEM pads with these, I have not felt the need to wash the car because of the brake dust which I did with OEM pads. They still have great brake feel, perhaps a little less initial bite than OEM but there's the tradeoff between low dust and performance...
Old Jan 4, 2014 | 10:12 PM
kimguroo's Avatar
kimguroo
Hawk HPS pads +1
less dust than OEM pad.
Old Jan 5, 2014 | 03:44 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We recommend and use the EBC Redstuff pads in our shop. They are much less dust and perform better than the OEM.
I don't recommend the Hawks as we've never had good luck on a MINI with them.
Old Jan 5, 2014 | 03:49 PM
cristo's Avatar
cristo
Alliance Member
Hawk HPS pads had way less dust than OEM and they last longer than and cause less
rotor wear, but initial bite was only so-so.
I currently have CoolCarbon pads which have better inital bite and I like the performance
better than HPS or OEM, but the dust is about halfway between HPS and OEM in amount.
Old Jan 22, 2014 | 10:40 AM
2010CHILI's Avatar
2010CHILI
+1 for Hawk HPS or Ceramic
Old Jan 22, 2014 | 10:57 AM
InjectedGT's Avatar
InjectedGT
Seeing how many people are recommending Hawk pads based on their experience, I wonder if Way doesn't recommend them because they had bad luck with them, or if they "don't recommend them" because they don't sell them? :P
Old Jan 22, 2014 | 11:44 AM
2010CHILI's Avatar
2010CHILI
my mini is the third car I have put Hawk HPS or Ceramic pads on, and have been happy with all 3
Old Jan 22, 2014 | 02:52 PM
ashchuckton
Are the EBC brakes still having separation issues? I would not use them until EBC addresses the problem with them.
Old Jan 22, 2014 | 03:21 PM
Capt_bj's Avatar
Capt_bj
I've used EBC for 10+ years ... started with green then went to red (on the MINI)
never a problem with green
but WAY happy with less dust on red
BUT I use solid rotors and a bud of mine with slotted rotors sees BIG DUST with EBC red . . . hmmmmmmm
Old Jan 25, 2014 | 11:04 AM
richardsperry's Avatar
richardsperry
Another Red...
Old Jan 25, 2014 | 10:27 PM
minsanity's Avatar
minsanity
If you don't track......Bendix Ceramics!!!!!
Old Jan 26, 2014 | 12:33 AM
Mr Bentwrench's Avatar
Mr Bentwrench
I use the Akebono ceramics primarily because they were cheaper and easier to find. The difference in ceramic dust over OEM is amazing. Before, when the front was bad, the rears only seemed maybe half as bad. Now it takes the rear to get bad before the front even starts to show. Now I need to put some on the rear this spring when we do tires and wheels.
Old Feb 9, 2014 | 07:40 AM
rac427's Avatar
rac427
+1 for the EBC Red
I had the EBC Red in both front and rear, less dust than the original pad! you will lose the "initial bite" but personally I feel like it is a good thing!
But beware, EBD Red tend to have a very long break in period. Some say 1000miles and some says 3000. In my case, it took almost 5k miles.
Old Feb 24, 2014 | 08:37 PM
RJKimbell's Avatar
RJKimbell
I'm running Akebono EuroCeramic Brake Pads and Zimmermann Rotors...awesome setup for the PNW!!
Old Feb 24, 2014 | 09:46 PM
Minian's Avatar
Minian
+1 for the Akebono Euro Ceramic. Cleanest pad I've used
Old Feb 25, 2014 | 04:49 AM
netma1000's Avatar
netma1000
Red for street, yellow for track and street when dust is the least of your concerns
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
HaveATank
Aug 24, 2015 10:26 AM
