R56 LED lights
Old Dec 21, 2013 | 01:01 PM
RicWRX's Avatar
RicWRX
LED lights
I installed ziza bulbs in the parking and license plate lights today, everything working fine. Installed superbrite LED turn signals in the front (can bus), they work fine. I then installed the same kind of bulbs in the rear turns, they are hyper blinking. What is up with this. Can I get an LED flasher.
Old Dec 21, 2013 | 03:48 PM
vetsvette's Avatar
vetsvette
Moderator
There are digital flashers available, but I don't know about a Mini application. I installed one on my Suburban and it works great.
Old Dec 21, 2013 | 03:54 PM
babysarah's Avatar
babysarah
What exactly is the point of changing out any of the turn signals to LED ??
Canbus LED's for our cars are to eliminate the error code we will get without them. You don't get enough resistance to use them on their own without getting hyperflash.
The turn signals work inline. So you probably got lucky when switching out one turn signal to a canbus LED and still having your rear factory signals. However, the canbus LED's alone won't create the resistance you need. Resistors are standard, and recommended, for just about any vehicle (not just MINI's) to prevent hyperflash.
Old Dec 21, 2013 | 04:14 PM
M'Cooper's Avatar
M'Cooper
It would have been nice if our cars had led lights. I like the instant on/ off.
Old Dec 21, 2013 | 05:26 PM
RicWRX's Avatar
RicWRX
I had a special LED flasher on my WRX, it worked fine. I wanted to know if there was one for the Mini.
Old Dec 21, 2013 | 05:58 PM
bmrguy03's Avatar
bmrguy03
Just code it out
Old Dec 21, 2013 | 08:07 PM
babysarah's Avatar
babysarah
I don't know if there is a flasher available for our cars. Either way, the load resistors accomplish the same thing and are installed parallel to the positive and negative. A little more work. They are the only components I've ever seen used by professionals for the LED turn signals.
Old Dec 21, 2013 | 08:42 PM
danjreed's Avatar
danjreed
^ This 100X
timwhayden
Aug 24, 2015 08:42 PM
Lschneider
Aug 21, 2015 02:21 AM
I_drive_slow
Aug 18, 2015 10:47 AM
