vacuum pump, lines, tank and pressure converter
Old Dec 21, 2013 | 12:14 PM
shanksamillion's Avatar
shanksamillion
I'm trying to replace the vacuum lines. How can I get better access to vacuum tank? It's very hard to reach from directly below? Would coming in through the side by removing passenger tire be easier? Also lots of oil on both ends of this vacuum line connecting vacuum pump and vacuum tank. I think there is some oil in the line too. Is this normal? If not how the heck did oil get in there? Can I blow it out with air compressor or do I need to replace the whole darn line? Had trouble pasting the diagram here is a link if your unfamiliar the vacuum system http://parts.miniofconcord.com/a/MIN...R/11_3982.html
Old Dec 21, 2013 | 04:28 PM
micromini234's Avatar
micromini234
There shouldn't be. As for replacing them I can't give any more information I just took the manifold completely off and went from there.
Old Dec 21, 2013 | 07:04 PM
shanksamillion
Thanks. So I I blew out the lines with air compressor just to be sure and replaced the rubber hose sections at the end. It worked! I had leaks eveveywhere. Replaced charge air tube (cracked at turbo), replaced valve cover (very audible air leak), and today the vacuum lines. Problem finnaly fixed! No more reduced power light.
Old Aug 5, 2017 | 12:13 AM
Terry Thrasher's Avatar
Terry Thrasher
Vacuum lines Diagram
By any chance you wouldn’t happen to have a diagram of how the vacuum lines went back together because after I put everything back together when I try to start the car it stutters s and I believe the vacuum lines are the problem. I had a few weeks in the hoses and I replaced the vacuum lines but now I don’t remember how to put them back on correctly .
Old Aug 5, 2017 | 02:34 PM
oldbrokenwind's Avatar
oldbrokenwind
Time for you to learn about our Real OEM illustrated Parts List --- http://www.realoem.com/bmw/enUS/select just enter the last few characters of your VIN, and everything you ever wanted to know about your Mini's construction will be available. Well, almost everything. The section you're interested in is under Engine --- Vacuum Control --- Vacuum Control-Engine-Turbo Charger.
Old Nov 2, 2018 | 07:06 AM
danraabe's Avatar
danraabe
Vacuum questions
how to find the page yo7 are suggesting
Old Nov 2, 2018 | 11:14 AM
oldbrokenwind
Click on the link to get into the site
Enter the last 7 characters of your VIN in Serial Number
Click on Search
Verify info describes your car
Click on Browse Parts
Select Engine
Scroll down to Vacuum Control
Click on Vacum Control - Engine Turbo Charger
The one hose without dotted lines goes to the vacuum pump.
marendt428
Nov 14, 2015 10:03 AM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
scottrn
Aug 22, 2015 07:26 PM
patrioticmini
Aug 20, 2015 10:54 AM
marendt428
Aug 8, 2015 04:44 AM
