Navigation & Audio Classic IPod connection
Old Dec 5, 2013 | 01:00 PM
Ishihara's Avatar
Ishihara
hey everyone... I've tried a bunch of searches to see if I could find an answer, but... no such luck... stopped by the dealer today to pick up the IPod/USB connector as my car was spec'd with it but it was long gone when I got it... the stereo instantly read the IPod, song title, etc... I could change tracks... but I have NO sound - zero... tried the clickwheel, the volume ****, the control panel... I couldn't get even static...
thoughts?
Old Dec 5, 2013 | 09:00 PM
Btwyx's Avatar
Btwyx
What year of MINI and which iPod connector?
With a Y connector I'd check the audio plug is plugged in correctly. With the 30 pin flying lead, I'd suspect its not installed correctly.
Old Dec 6, 2013 | 07:25 AM
Ishihara's Avatar
Ishihara
it's a 2010 MCS and it's an old IPod Classic... I'll be sure to try the connection again today for the drive to work... admittedly, it was a little rushed trying to get out of the dealer lot yesterday...
Old Dec 6, 2013 | 10:26 AM
Btwyx's Avatar
Btwyx
Still the question of which iPod connection you have. Is it the one with the Y cable? (30 pin on one end, box in the middle and USB and audio plugs on the other.) Or do you have the dealer installed one where a white 30 pin connector emerges in the glovebox or hidden compartment?
Old Dec 7, 2013 | 08:14 AM
Ishihara's Avatar
Ishihara
sorry about that... it's a dealer supplied Y cable with the connection at the base of the dash, below the stereo...
Old Dec 7, 2013 | 07:03 PM
Btwyx's Avatar
Btwyx
First would be to make sure the audio plug is plugged in correctly.
Next check the level. I think you should have a button labled "Lev" on the main screen. Make sure that's at a reasonable volume.
Next you could try plugging something else in the audio portion (without the USB part), and see if you get any sound when you select Aux.
Old Dec 8, 2013 | 03:37 AM
lathedog's Avatar
lathedog
Turn volume all the way up on iPod and it will work
Old Dec 9, 2013 | 07:20 PM
Btwyx's Avatar
Btwyx
If he's using the Y cable, iPod volume has no effect on the audio output.
Old Dec 13, 2013 | 05:08 PM
richardsperry's Avatar
richardsperry
My money is on the aux volume level.
Old Dec 15, 2013 | 06:32 AM
Ishihara's Avatar
Ishihara
and you would be correct... and man, do I feel like an idiot for missing that one the three times I went through the menu... thanks for your help everyone!
RobbyD
Jan 29, 2019 01:22 PM
pglgp1292
Aug 9, 2017 12:45 PM
gar56
Nov 15, 2016 06:41 AM
krohm
Sep 28, 2015 12:16 PM
