R50/53 NCSExpert for R53?
NCSExpert for R53?
I have a friend that uses ncsexpert on his BMW M3 to do some pretty neat stuff. He said he could try it in my R53 mini, but I wanted to get some more info on it first. I've searched the site and found lots of code, spreadsheets, and how-to's for the R56 minis....but not much info on the R53's .
Has anyone used NCSexpert to get in and place with some of the functions and controls on your R53?
Any info would be great. Thanks!
There are a couple of useful threads on here for the R53s. I recently did mine and it wasn't to tricky. Not all the options work on all cars. I programmed a few things like daytime running lights, auto up for both driver and passenger windows, follow me home lights, changed the door locking & unlocking options. I'll try to find the threads and post them here, but it was essentially the same as the r56s.
I used it to enable the feature of closing the windows with the key fob. No loner have to stick the key in the door.
Also, when using it be sure to have a battery tender hooked up to the car and make sure the OBD cable connections don't work loose during the coding process. There are risks to bricking the module if you're not careful.
I was looking forward to having that option enabled, but I couldn't do it on my 2003. That or changing the number of light flashes when locking and unlocking. One touch auto up for both windows is pretty nice though, and auto unlock when ignition is turned off eliminates the annoying double pull of the door handles.
Also, try downloading "NCS Dummy." It a freeware program that makes TRC file edits extremely simple. It deciphers all the esoteric crap you's normally have to figure out yourself.
I used NCS dummy. It did help to decipher things, but I still had to edit the trc file in text edit. For some reason it didn't let me use any of the check boxes. Perhaps there is something wrong with my code. I can't remember what month my 2003 is from, but I think it is an 08/2003, which gives me hope that I'll be able to get the remote closing or to work. If you wouldn't mind sending me a copy of, or uploading your trc file, that would be awesome.
Just a troll.....
Must have sold his mini, but still hangs out with mini folks here...
Him...sounds like he WISHES he still had his mini or he would have deleted his account.
I've attached a copy of my TRC file but changed the file extension so this forum would let me upload it. IIRC, to get the comfort close with the key fob to work all I had to change was "REMOTE_LAZY_LOCK" to "activ"
Good Luck!
PS - It's better to just ignore the trolls. Otherwise you'll just encourage them.
troll food.....
In order for the check boxes to show up, you have to read the TRC from the module and then load it into NCS dummy by clicking the browse button near the top. See attached. When you've made the necessary changes export it to the MAN file by clicking on the export button near the bottom.
Good Luck!
Good Luck!
One thing that tripped me up when I first started using NCS: after coding a module, restart NCSexpert and re-read the TRC from the module you just coded to make sure the changes you made actually took effect. If NCSexpert isn't set up properly the coding won't take and it can become an infuriating annoyance.
Quick tip while using NCSdummy: load the chassis and TRC file first, then use the filter button to allow NCDdummy to figure out which module you're trying to code. Manually picking the wrong module is too easy.
-and yes, I don't have a sunroof
Any one have a Trace file (*.TRC) for a 2006 R53 Mini Cooper S, Body, ABE MRSK5CD.C22 FSW/PSW.TRC ? My Mini had an accident and insurance authorized repair place replaced ABE module and right side curtain airbag. Car looks good and runs good, but I have Airbag light and Seatbelt light. He gave the car back to me that way with 14 Airbag codes. I want to compare what .TRC from unaltered car and file. He sent car out to fix the Airbag codes and I think second shop altered the file.
* Disabled seat belt gong. The seatbelt light only comes on during initial startup as a bulb check, then disappears.
* Disabled NAS mode for the front fog lights. Now they operate as they would on a ECE-spec car (fog lights work with parking lights, low beams, and high beams)
* Enabled comfort opening via key in door handle. My car came with comfort closing already enabled for the key in door handle.
* Enabled comfort closing via remote. This doesn't work as I expected. I have to hit the lock button multiple times for this to work, even w/ new batteries in my remote. My car came with comfort opening w/ remote already enabled.
* Enabled double blink hazard lights (my favorite mod so far)
* Enabled the clock in the speedometer (now I have two - factory one in the headliner, and the one in the speedo. They are not linked, can be set to different times if desired)
* Changed the front wipers to wipe 4 times during a wash cycle instead of 3.
* Changed the headlight washers to power wash every 3 times the front washers are used (still have not tested this - it was previously set to 7, and I could only get them to wash one time unless I cycled the headlights on/off)
* Removed the leading zero on my odometer. So instead of reading 062964, it reads 62964. Looks less cluttered now.
* Changed the 'number of visual unlocking acknowledges' from 2 to 3.
* Changed the remotes so that pressing unlock 1 time unlocks all doors/boot.
* Disabled wipers stepping down in speed when the vehicle is stopped. (have not tested this yet)
* Enabled low fuel warning gong (fuel not low enough to test yet)
* Disabled low temperature warning gong. Quite annoying in the fall when temps hover right around 37*F.
* Disabled cold and warm bulb checks for the parking lights and turn signal bulbs, so I can upgrade to LEDs in the future and not have any hyper flashing or random strobe effect.
If you'd like to look at my .trc files, let me know. More than happy to share since this info isn't widely available on the 'net for our R50/52/53s.
https://www.northamericanmotoring.co...de-add-in.html
I decided to jump into relatively uncharted waters last night (R50/53 NCSExpert settings) and changed the following on my car ('04 R53):
Thanks!
I'll get you my .trc files in just a bit (need to find them).
Here's the trace file for my car's BC1. I've highlighted anything I've changed from its factory/dealer configuration to RED
Code:
FH_FAHRERTUER_TIPP_AUF
aktiv
FH_BEIFAHRERTUER_TIPP_AUF
aktiv
DWA
aktiv
SCHAERFEN/ENTSCHAERFEN
schloss_und_fernbedienung
PANIK_MODUS
aktiv
FUNK_INNENRAUMSCHUTZ
aktiv
QUIT_AKUST_SCHAERF
nicht_aktiv
QUIT_AKUST_ENTSCH
nicht_aktiv
QUIT_OPT_ENTSCH
aktiv
QUIT_OPT_SCHAERF
nicht_aktiv
NEIGUNGSGEBER
aktiv
ALARM_AKUSTISCH
aktiv
BEDIENSTELLE_BFT
nicht_aktiv
FH_ABSCHALTKRITERIUM
wert_03
FH_NACH_TUERE_AUF
nicht_aktiv
FUNKTION_CABRIO
nicht_aktiv
EINKLEMMSCH_REVERSIEREN
nicht_aktiv
ALARM_AKUSTISCH_LANG
nicht_aktiv
IB_BEI_KL.R_AUS
aktiv_mit_kl.58
KALTUEBERWACHUNG_NSL
nicht_aktiv
KALTUEBERWACHUNG_NSW
aktiv
SCHEINWERFERREINIGUNG
aktiv
CC_BREMSLICHT
aktiv
ALARM_OPT_ABBLENDLICHT
nicht_aktiv
ALARM_OPT_FERNLICHT
aktiv
ALARM_OPT_WARNBLINKER
aktiv
LEUCHTWEITENREG_AUTOM
aktiv
VERRIEGELN_AUT_AB_X_KM/H
nicht_aktiv
WISCHERINTERVALL
wert_02
ZV_SELEKTIV
nicht_aktiv
CLT_AKTIV_IM_CRASH_MODE
nicht_aktiv
CODIERUNG_ERFOLGT_1
codierung_erfolgt
ENTSICHERN_CENTERLOCK
nicht_aktiv
INNENLICHT_AN_MEHRFACH_ZV
aktiv
KOMFORTSCHLIESSUNG_FB
aktiv
STANDRUECKSCHALTUNG
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_1
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_2
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_3
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_4
nicht_aktiv
VERZUG_PANIK_MODUS_0.2_S
wert_01
VERRIEGELN_AUT_NACH_2_MIN
aktiv
VERRIEGELUNGSSCHWELLE
16_km/h
ABFRAGEZEIT_AHM
wert_01
ABSCHALTUNG_UNTERSPG
wert_01
ENTPRELLZAHL_FEHLERERK
wert_01
KALTUEBERWACHUNG_AL
nicht_aktiv
KALTUEBERWACHUNG_FL
aktiv
ABSTAND_HOLD_NORMAL_MODE
wert_02
HALB/VOLLSCHRITT
halbschritt
HYSTERESE_STARTBEDINGUNG
wert_01
KALTUEBERWACHUNG_BLK_HI
nicht_aktiv
KALTUEBERWACHUNG_BLK_VO
nicht_aktiv
SCHRITTABSTAND_GRENZE
wert_01
SCHRITTABSTAND_STARTPHASE
kennlinie_01
TEMPERATUR_GRENZE
grad_-20
ABS_MIN_STELLUNG_2
wert_02
GED_FL_ALS_DRL
nicht_aktiv
HEIMLEUCHTEN
wert_02
SCHRITTE_STELLUNG_0
wert_01
wert_02
SCHRITTE_STELLUNG_1
wert_04
SCHRITTE_STELLUNG_2
wert_04
TAGFAHRLICHT_ECE
nicht_aktiv
U_POTI_STELLUNG_0
wert_01
U_POTI_STELLUNG_1
wert_01
U_POTI_STELLUNG_2
wert_01
BLS_PRUEFEN
nicht_aktiv
ABSENKUNG_10_KM/H
wert_01
ABTASTRATE_DYN
wert_01
ABTASTRATE_TREND
wert_01
ABWEICHUNG_TREND
wert_01
ANHEBUNG_175_KM/H
wert_01
ANZAHL_QUICK_RUNDEN
wert_01
AUSWERT_GRADIENT
aktiv
AUSWERT_PROP_ABWEICHUNG
aktiv
DAUER_DYN_NACHFUEHRUNG
wert_01
DEF_LWR_SENSOR_HI
wert_01
DIFFERENZ_MSP_DYN_STAT
wert_01
EPSILON_DELTA_A
wert_01
EPSILON_DELTA_AV
wert_01
GRADIENT_SCHLECHTWEG
nicht_aktiv
HOEHENWEG
wert_01
KALTUEBERWACHUNG_KZL
nicht_aktiv
KENNLINIE_LWR_SENSOR_HI
wert_02
KENNLINIE_LWR_SENSOR_VO
wert_01
LEUCHTWEITENREG_DYNAM
nicht_aktiv
LEUCHTWEITENREGELUNG
aktiv
LWR_NEIGUNG_KONSTANTE
wert_01
LWR_VORZEICHEN
wert_01
M_TELEGRAM
nicht_aktiv
MIN_STEIGUNG_VZ_WECHSEL
wert_01
MINDESTANZAHL_VZ_WECHSEL
wert_01
MITTELUNGSINTERV_DYN
wert_01
MITTELUNGSINTERV_TREND
wert_01
MITTELUNGSINTERV_VZ_WECHS
wert_01
NACHLAUF_SCHLECHTWEG
wert_01
OFFSET_LWR
wert_01
PWM_ANSTEUERUNG_KZL
wert_01
REFERENZL_MODE_TEIL1
wert_01
REFERENZL_MODE_TEIL2
wert_01
REFERENZL_SCHRITTABSTAND
wert_01
REFERENZL_SCHRITTANZAHL
wert_01
SAETT_TIMER_SCHLECHTWEG
aktiv
SCHW_GRAD_BESCHLEUNIGUNG
wert_01
wert_02
SCHW_GRAD_BREMSEN
wert_01
wert_02
SCHW_GRADIENT_SCHLECHTWEG
wert_01
SCHW_PROP_ABWEICHUNG
wert_01
wert_02
SCHW_TREND
wert_01
SP_MOTOR_BEWERTEN
aktiv
SP_MOTOR_F_EINTRAG
aktiv
SP_MOTOR_STOP
aktiv
TREIBER_BEWERTEN
aktiv
TREIBER_F_EINTRAG
aktiv
VMAX_BESCHLEUNIGUNG
wert_01
VMAX_BREMSEN
wert_01
VMIN_BESCHLEUNIGUNG
wert_01
VMIN_BREMSEN
wert_01
WARMUEBERWACHUNG_KZL
nicht_aktiv
ZEIT_KALT_PULSE
wert_01
ZEIT_KALT_PULSE_QUICK
wert_01
ZEIT_KALT_RUNDEN
wert_01
ZYKLUS_KALT_RUNDEN_QUICK
wert_01
AC_AUTO
aktiv
AC_BASIC
nicht_aktiv
AUXILIARY_LAMP_ENABLE
nicht_aktiv
BOOT_RELEASE_ENABLE
aktiv
CLUTCH_OFF
wert_01
CLUTCH_ON
wert_01
DAYLIGHT_RUN_POWER
wert_01
DEFAULT_EXT_AMBIENT_TEMP
nicht_aktiv
DIPPED_BEAM_NAS
nicht_aktiv
ENTRIEGELN_B_MOTOR_STOP
nicht_aktiv
FOG_DISABLE_WITH_TRAILER
aktiv
FRONT_FOG_NAS
nicht_aktiv
HALTEN_FB_OEFFNEN_TASTE
ohne_funktion
HFS
nicht_aktiv
HFS_HIGH_TEMP_TIME
wert_01
HFS_LOW_TEMP_TIME
wert_01
HR_HIGH_BAT_THRESHOLD
wert_01
HRW_HIGH_TEMP_TIME
wert_01
HRW_LOW_BAT_THRESHOLD
wert_01
HRW_LOW_TEMP_TIME
wert_01
INDICATE_DURING_HAZARD
aktiv
KEY_DISARM
aktiv
KOMFORTOEFFNUNG_SCHLOSS
aktiv
MAN_WISCHEN_IM_WASCHPROG
aktiv
NO_SOFT_ON_OFF
nicht_aktiv
PARKING_LIGHTS
nicht_aktiv
POWER_WASH_OFF_TIME
wert_01
POWER_WASH_ON_TIME
wert_02
REAR_WIPER_CONTINUOUS
nicht_aktiv
REMOTE_CONTROL
aktiv
SENSOR_REGEN
nicht_aktiv
WINDOW_AUTO_UP_DRIVER
nicht_aktiv
WINDOW_AUTO_UP_PASS
nicht_aktiv
WINDOW_INCH_AUTO
aktiv
WINDOW_SUNROOF
aktiv
WIPER_BOOT_INHIBIT
nicht_aktiv
WIPER_CAM_DELAY
wert_01
WIPER_NO_PROG_REAR_WASH
nicht_aktiv
WIPER_REAR_CAM_DELAY
wert_01
WIPER_WASHER_START_TIME
wert_01
WISCHER_GESCHW_ABHAENGIG
nicht_aktiv
FRONT_FOG_ENABLE
aktiv
HEADLAMP_LEVEL_TYPE
lwr_intern
INERTIA_SW_FITTED
nicht_aktiv
REAR_FOG_ENABLE
aktiv
ABSCHALTUNG_VERBRAUCHER
aktiv
AL_AUS_BEI_KL_50
nicht_aktiv
ANHAENGERMODUL_PWM_WERT
wert_01
ANLAUFSTROMBEGRENZ_MEMO
nicht_aktiv
ANSTEUERZEIT_MOTOR_HK
wert_01
ANSTEUERZEIT_ZV_AGGREGATE
plus_0ms
ANZAHL_NACHWISCHZYKLEN
ANZAHL_SPRITZIMPULSE
ANZAHL_WASCHBET_ZUR_SRA
AUSSENTEMP_SENSOR
aktiv
BEDIENSTELLE_FT
aktiv
BETR_STD_NICHT_LOESCHEN
aktiv
BETRMODI_DEAKT_KL15_EIN
nicht_aktiv
BLINKIMPULS_WARNBLK
aktiv
BLOCKIERSCHUTZ_AKT_XXS
wert_01
BLOCKIERSCHUTZ_HI_AKT_XXS
wert_01
CABRIO_FH_VO_ZEIT_AUF
1000ms
CABRIO_FH_VO_ZUERST_AUF
aktiv
CABRIO_FH_VO_ZUERST_ZU
nicht_aktiv
CENT_LOCK_MGL_VO_TUER_AUF
nicht_aktiv
CODIERUNG_ERFOLGT_0
codierung_erfolgt
CODIERUNG_ERFOLGT_4
codierung_erfolgt
CODIERUNG_ERFOLGT_5
codierung_erfolgt
CODIERUNG_ERFOLGT_6
codierung_erfolgt
CODIERUNG_ERFOLGT_7
codierung_erfolgt
DIFFERENZ_ANLAUF_BLOCK
wert_01
DRITTE_TASTE_SENDER
wert_01
DWA_HEKKLEPPENKONTAKT
aktiv
EINKLEMMSCH_VORNE
nicht_aktiv
EINSTEIGHILFE
nicht_aktiv
EINSTIEG_FH_ZU_VER_SPERRE
nicht_aktiv
EKS_GEDRUECKT/OFFEN
wert_01
EKS_OFFEN/UNTERBRECHUNG
wert_01
EKS_REVERSIERZEIT_ZUS
wert_01
ENTR_HKL_MGL_WENN_VER
nicht_aktiv
FE_MODE_JEDOCH_MIT_FB
nicht_aktiv
FERNBEDIENUNG_1
zv_selektiv
FERNBEDIENUNG_2
zv_selektiv
FERNBEDIENUNG_3
zv_selektiv
FERNBEDIENUNG_4
zv_selektiv
FH_ABSCHALTEN_BLOCK_AUF
wert_01
FH_ABSCHALTEN_BLOCK_ZU
wert_01
FH_ANHEBEN_TRANSPORTMODE
aktiv
FH_BLOCKABSCHALT_TUER_AUF
wert_01
FH_HINTEN_TIPP_AUF
aktiv
FH_HINTEN_TIPP_ZU
nicht_aktiv
FH_INIT_TRANSPORTMODE
nicht_aktiv
FH_SPEICHERN_TRANSPORTMOD
aktiv
FH_TIMEOUT
15sec
FL_AUS_BEI_KL_50
nicht_aktiv
FRISCHLUFT_PARKPOSTITION
aktiv
FZV_TIMEOUT
wert_02
HFS_ON_TIME_LOW_VOLTAGE
wert_01
HKL_SPERREN_BEI_ZS
nicht_aktiv
HRW_NUR_BEI_GESCHL_VERDEK
nicht_aktiv
HRW_ON_TIME_LOW_VOLTAGE
wert_01
HUB_VERZOEGERUNG_FH_VORN
0ms
IB_AUS_NACH_X_SEKUNDEN
20s
IB_BEI_KL.R_AUS_OHNE_58G
ohne_bedingung
IB_EIN_16MIN_WENN_STANDLI
nicht_aktiv
IB_EIN_BEI_HKK/HSK
aktiv
IB_EIN_N_KL_58G_MAX_1MIN
zwei_minuten
IB_EIN_SCHLOSS_ENTRIEGELN
aktiv
KALTUEBERW_AUS_BEI_KL_50
aktiv
KALTUEBERWACHUNG_BL
nicht_aktiv
KALTUEBERWACHUNG_BL_MI
nicht_aktiv
KALTUEBERWACHUNG_SL_H
nicht_aktiv
KALTUEBERWACHUNG_SL_V_I
nicht_aktiv
KALTUEBERWACHUNG_ZSW
nicht_aktiv
KEIN_HECKWISCHER
mit_heckwischer
KOMFOEFFNEN_SPERRE_KEY_IN
aktiv
KOMFORTOEFFNEN_FB_O_FH_HI
nicht_aktiv
KOMFORTOEFFNEN_FB_O_SHD
nicht_aktiv
KOMFORTOEFFNUNG_CLT
aktiv
KOMFORTSCHLIE_FB_O_FH_HI
nicht_aktiv
KOMFORTSCHLIE_FB_OHNE_SHD
nicht_aktiv
KOMFORTSCHLIESUNG_SCHLOSS
aktiv
KRB_WIE_VA/HKK_STATT_IB
nicht_aktiv
LAENDERVARIANTE_ECE
nicht_aktiv
LAENDERVARIANTE_US
aktiv
MAUT_N_ABBRECH_N_TUER_AUF
nicht_aktiv
MIN_PWM_TASTVERHAELTNIS
wert_01
MIT_AHM
aktiv
MIT_MFL
aktiv
MIT_OPT_ALARM
aktiv
MIT_WISCHER_SERVICEPOS
nicht_aktiv
N_VER_B_ERN_GESCHW_SCHWEL
nicht_aktiv
NSW_AUS_BEI_KL_50
nicht_aktiv
OFFENE_FENSTER
nicht_aktiv
OHNE_HRW
nicht_aktiv
OHNE_INRS_BESTAETIGUNG
ohne_bestaetigung
OHNE_SCHEIBENABSENKUNG
mit_absenkung
POTISTELLUNG_IN_77H
wert_01
PWM_ANSTEUERUNG_AL
wert_02
PWM_ANSTEUERUNG_BL
wert_01
PWM_ANSTEUERUNG_BLK_HI
wert_01
PWM_ANSTEUERUNG_BLK_VORN
wert_01
PWM_ANSTEUERUNG_FERNLICHT
wert_01
PWM_ANSTEUERUNG_IL
wert_01
PWM_ANSTEUERUNG_NSL
wert_01
PWM_ANSTEUERUNG_SL_H
wert_01
PWM_ANSTEUERUNG_SL_V_I
wert_01
PWM_ANSTEUERUNG_VA
wert_01
QUIT_AKUST_SCHAERF_KLAPPE
aktiv
QUIT_OPT_ANZAHL_ENTSICHRN
QUIT_OPT_ANZAHL_SICHERN
QUIT_OPT_SCHAERF_KLAPPE
aktiv
QUITIMP_SICHERN/ENTSICHER
aktiv
ROVER_FZV_STATT_BMW
rover_fzv
SCHEIBE_ABSENKZEIT
wert_01
SCHEIBENABSENK_OHNE_EKS
ohne_eks
SCHWELLE_GEBLAESESENSOR
wert_01
SCHWELLE_MERHK_KS
wert_01
SCHWELLE_MERHK_OL
wert_01
SENSOR_REGEN_N_STUFE2
stufe_2
TAUSCH_AUSGANG_NSL_NSW
nicht_aktiv
TRA_MODE_JEDOCH_MIT_FB
nicht_aktiv
UEBERSPGSABSCHALTUN_AL/FL
aktiv
UMLUFT_PARKPOSTITION
nicht_aktiv
VA1/VA2_AUS_NACH_X_MIN
16_min
VERL_ALARMZEI_WAEHR_ALARM
nicht_aktiv
VERZ_FRWISCHER_N_WASCHANF
wert_01
VERZ_HKWISCHER_N_WASCHANF
wert_01
VERZOEGERUNG_S56A_D_AUS
wert_01
VERZOEGERUNG_SHD_KOE
sofort
VERZOEGERUNG_SHD_KS
sofort
WARMUEBERWACHUNG_AL
aktiv
WARMUEBERWACHUNG_BL
nicht_aktiv
WARMUEBERWACHUNG_BL_MI
nicht_aktiv
WARMUEBERWACHUNG_BLK_HI
nicht_aktiv
WARMUEBERWACHUNG_BLK_VO
nicht_aktiv
WARMUEBERWACHUNG_FL
aktiv
WARMUEBERWACHUNG_NSL
nicht_aktiv
WARMUEBERWACHUNG_NSW
aktiv
WARMUEBERWACHUNG_SL_H
nicht_aktiv
WARMUEBERWACHUNG_SL_V_I
nicht_aktiv
WARMUEBERWACHUNG_ZSW
nicht_aktiv
WE_MODE_JEDOCH_MIT_FB
nicht_aktiv
WISCHER_RUECK_GESCHW
wert_01
WISCHER_VOLLEND_KLR_AUS
vollendung
WISCHERINTERVALL_HECK
wert_01
XENON_TEST
aktiv
XENON_TIME
wert_01
XENON_TIMEOUT
wert_01
ZEIT_TUER/SCHLIESSZEIT
wert_01
ZEIT_WASCH_M/O_HKWISCHER
wert_01
ZSW_AUS_BEI_KL_50
aktiv
KS_ABSCHALTUNG_AL
nicht_aktiv
KS_ABSCHALTUNG_BL
aktiv
KS_ABSCHALTUNG_BL_MI
nicht_aktiv
KS_ABSCHALTUNG_BLK_HI
aktiv
KS_ABSCHALTUNG_BLK_VO
aktiv
KS_ABSCHALTUNG_FL
nicht_aktiv
KS_ABSCHALTUNG_IB
aktiv
KS_ABSCHALTUNG_KRB
nicht_aktiv
KS_ABSCHALTUNG_KZL
nicht_aktiv
KS_ABSCHALTUNG_NSL
aktiv
KS_ABSCHALTUNG_NSW
nicht_aktiv
KS_ABSCHALTUNG_SL_H
nicht_aktiv
KS_ABSCHALTUNG_SL_I
nicht_aktiv
KS_ABSCHALTUNG_VA
aktiv
KS_ABSCHALTUNG_ZSW
nicht_aktiv
ALARM_MUW_SENSOR
nicht_aktiv
CABRIO_FH_KOMP_AUF_MIT_FB
nicht_aktiv
CABRIO_FH_NICHT_ZU_MIT_FB
nicht_aktiv
KALTUEBERWACHUNG_BL_MI_2
nicht_aktiv
KALTUEBERWACHUNG_IB2
nicht_aktiv
LWR_POS2
wert_02
LWR_POSR
wert_02
MIT_AUSSTIEGSLEUCHTE
nicht_aktiv
MIT_NSL_RECHTS
aktiv
PWM_ANSTEUERUNG_IB2
wert_01
WARM_WITH_OL_BTS716
nicht_aktiv
WARMUEBERWACHUNG_IB2
nicht_aktiv
ZENTRAL_FH_SCHALTER
nicht_aktiv
ZENTRAL_FH_SCHALTER_VERZ
wert_02
BLS_POLL_TIME
wert_01
ZENTRAL_FH_SCHALTER_MAUT
nicht_aktiv
FLC_FAILSAFE
nicht_aktiv
FLC_OHNE_RLS
nicht_aktiv
MIT_FLC
nicht_aktiv
MIT_FLC_SCHALTER
nicht_aktiv
MIT_WWA
nicht_aktiv
WWA_MOTOR_AN_ZEITZELLE
wert_02
WWA_MOTOR_AUS_ZEITZELLE
wert_02
WWA_SENSOR_ABTASTUNG
wert_01
ANLIEFERKODIERUNG
nicht_aktiv
KALTUEB_AUS_BEI_SCG
aktiv
KOMFORT_OEFFNEN_VERZ
wert_01
wert_02
KOMFORT_SCHLIESSEN_VERZ
wert_01
MAUT_NUR_BEI_MOTOR_AN
nicht_aktiv
TILT_SIRENE
aktiv
TM_ENTR_HECKKLAPPE
aktiv
WWA_LED_KL15_DAUER
wert_01
WWA_LED_MOT_DAUER
wert_01
WWA_LED_TAKT_AUS
wert_01
WWA_LED_TAKT_EIN
wert_01
WWA_LED_TRIG_DAUER
nicht_aktiv
WWA_LED_WASCH_DAUER
wert_01
And here's the tracefile for my car's KMB. I've highlighted anything I've changed from its factory/dealer configuration to RED:
Code:
CODIERUNG_ERFOLGT
codiert
K_ZAHL_TACHO
46463_imp/km
K_ZAHL_TACHO_KOMPL
46463_imp/km
TANK_SICHERHEITSFAKTOR
wert_01
TANK_SCHWELLE_RESERVE
8_l
TANK_MITTLUNGSZEIT
wert_01
TANK_BERUHIGUNGSZEIT
wert_01
K_ZAHL_WEG
46463_imp/km
K_ZAHL_WEG_KOMPL
46463_imp/km
MOTOR_ART
benziner
SPRACHE
us
ZEIT_EINHEIT
24_stunden
TEMPERATUR_EINHEIT
grad_f
WEGSTRECKE_EINHEIT
mls
WEG_DURCHSCHNITT
km/h
VERBRAUCH_D1
mpg_us
BC
aktiv
ASC
aktiv
LL/RL
linkslinker
GURTWARNUNG
ohne_gurtschlosskontakt
TANK_SCHWELLE_AUF/ABw
wert_01
SIA_GRENZE_INSPEKTION
11.000_km
SIA_GRENZE_ZEIT
0_tage
SIA_LITER_GRENZE
1.6_cooper_s
AUSSENTEMP_DELTA_K1
wert_01
AUSSENTEMP_ZEITKONST_Z1
wert_01
AUSSENTEMP_ZEITKONST_Z2
wert_01
LICHTWARNUNG
aktiv
GETRIEBE_ART
handschalter
TANK_VORHALT_REICHW
wert_01
WEG_EINHEIT
mls
LETZTER_SERVICE
grundcode_var
AKUSTIK_DWS
aktiv
DWS
aktiv
ZUENDSCHLUESSEL_WARNUNG
nicht_aktiv
AUSSENTEMP_WARN_AKUSTIK
nicht_aktiv
LIMIT
nicht_aktiv
GONG_1
wert_01
ANZEIGE_FUEHRENDER_NULLEN
nicht_aktiv
KALIBRIERUNG_TACHO
wert_01
LCD_DIMMUNG_MAX
wert_01
LCD_DIMMUNG_MIN_NACHT
wert_01
LCD_DIMMUNG_MIN_TAG
wert_01
REMOTE_KOMBI
dzm
AUSSENTEMP_SENSOR
aktiv
A_TEMP_DELTA_OFFSET
wert_01
A_TEMP_OFFSET_SCHWELLE
wert_01
AKUSTIK_TANK_RESERVE
aktiv
AKUSTIK_WARN_UEB_LEITUNG
nicht_aktiv
AKUSTIK_WARN_UEBER_BUS
aktiv
AUSSENTEMP_DELTA_K2
wert_01
AUSSENTEMP_SPERRZEIT_2
wert_01
AUSSENTEMP_SPERRZEIT_3
wert_01
AUSSENTEMP_ZEITKONST_Z3
wert_01
AUSSENTEMP_ZEITKONST_Z4
wert_01
BC_GESCHW_ANZEIGE_DIGITAL
aktiv
BC_TWSZ_2
aktiv
BREMSFLUESS_FILTER_ZEIT
25_sec
BREMSFLUESSIGKEIT_UEBER
can_bus
GONG_FREQ2
wert_01
KALIBRIERUNG_WEGSTRECKE
wert_01
KOMBI_TYP
us
MOTORHAUBE_OFFEN_WARNUNG
aktiv
ODOMETER_OFFSET
wert_01
PREDRIVE_CHECK
aktiv
RUECKWAERTSGANG_WARNUNG
nicht_aktiv
SCHWELLE_DZM_WARNFELD_1
nicht_aktiv
SCHWELLE_DZM_WARNFELD_2
nicht_aktiv
SCHWELLE_DZM_WARNFELD_3
nicht_aktiv
SCHWELLE_DZM_WARNFELD_4
aktiv
STOPPUHR_0_AUF_100
nicht_aktiv
STOPPUHR_1/4_MEILE
nicht_aktiv
TANK_1_ADC_FEHLER_OG
wert_01
TANK_1_ADC_FEHLER_UG
wert_01
TANK_2_ADC_FEHLER_OG
wert_01
TANK_2_ADC_FEHLER_UG
wert_01
TANK_FEHLER_SCHWELLE
wert_01
TANK_SCHW_RES_HYSTERESE
wert_02
TANKDAEMPFUNG_FAHRT_AB
wert_02
TANKDAEMPFUNG_FAHRT_AUF
wert_02
TANKDAEMPFUNG_NORMAL_AB
wert_01
TANKDAEMPFUNG_NORMAL_AUF
wert_01
TANKGEBER_1_LITER
kennlinie_02
TANKGEBER_2_LITER
kennlinie_02
TLETZ
wert_01
UEBERTEMP_WARNUNG
aktiv
VERBRAUCH_2
nicht_aktiv
VES_INFO
r50
WARN_GESCHW_LIMIT
nicht_aktiv
ZEITINSP_DISPLAY_FLAG
icon_wird_nicht_angezeigt
ZEITINSPEKTION
nicht_aktiv
ZEITINSPEKTION_VORGEZOGEN
nicht_aktiv
ANZEIGE_CFC
aktiv
AUSGABE_FEHLERSPEICHER
aktiv
BC_ANZ_NACH_ATEMP_WARN
aktiv
BC_QUITT_ATEMP_WARN_LSS
aktiv
CC_AUSSENTEMPERATUR
aktiv
DWS_UEBER
can_bus
TANK_NICHT_MESSBAR_OBEN
wert_02
BC_NAVI_VISUELLE_WARNUNG
nicht_aktiv
BC_RW_VERB_U_GRENZE
wert_01
SIA_TAGE_BEI_SERVICE
wert_01
SIA_TIME_SERVICE_COUNTER
wert_01
TANKDAEMPFUNG_STAND_AB
wert_01
TANKDAEMPFUNG_STAND_AUF
wert_01
BC_AKTUELLER_VERBRAUCH
aktiv
BC_DURCHSCH_GESCHW
wie_tacho
BC_GESCHW_ANZEIGE_GESCHW
wie_tacho
BC_GESCHW_ANZEIGE_KBUS
nicht_aktiv
BC_LIMIT_GESCHW
wie_tacho
BREMSBELAGVERSCHL_WARN
aktiv
MOTOR_OELSTAND_AUSWERTEN
nicht_aktiv
UHR
aktiv
Last edited by AKIndiMini; Oct 2, 2015 at 04:23 PM. Reason: Highlight changes in red.
