Wheels, how wide can you go.
Normally we would not recommend anyone using different size width rims for front and rear but I think in the case you mentioned this was a track MINI with wide wheel arch flares?
Using the stock fenders you can order up to 18x7.5" rims at tirerack.
Using wider wheel arches I think one could go as wide as 9" but you might want to confirm this with Alex@tirerack
or with Dan at Piloracing.com who sells the wide arches.
http://www.piloracing.com/cgi-bin/st...amp;s=WIDEBODY
_________________
MINIlani home of Jasmine Trias
_________________
humm...wider wheel/tire combo on the rear of a FF platform...
something doesn't chime in. Ive seen narrower wheel/tires on the
rear of a FF sportcompact race car which mades sense.
but i guess this is only for show.
I think you'd only want wider wheels on the front if you had an understeering problem. I think the rear sway takes pretty good care of that on the Mini.
Stay all 4 the same!
Alex
Colt45Magnus
Sep 7, 2015 10:47 PM
AdrenaliNate
Aug 24, 2015 12:37 PM
Aug 21, 2015 11:25 AM
