Wheels, how wide can you go.
Old May 24, 2004 | 06:30 PM
RSpeed's Avatar
RSpeed
What is the widest any one has seen front & rear?
Old May 24, 2004 | 07:28 PM
kenchan's Avatar
kenchan
8"
Old May 24, 2004 | 07:34 PM
RSpeed's Avatar
RSpeed
I have seen 8.5 Rear and 8 Fronts
I am wondering if any one has or has seen 9s??
Old May 24, 2004 | 08:52 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Normally we would not recommend anyone using different size width rims for front and rear but I think in the case you mentioned this was a track MINI with wide wheel arch flares?
Using the stock fenders you can order up to 18x7.5" rims at tirerack.
Using wider wheel arches I think one could go as wide as 9" but you might want to confirm this with Alex@tirerack
or with Dan at Piloracing.com who sells the wide arches.
http://www.piloracing.com/cgi-bin/st...amp;s=WIDEBODY
_________________
MINIlani home of Jasmine Trias
Old May 24, 2004 | 09:03 PM
lotsie's Avatar
lotsie
Old May 24, 2004 | 09:50 PM
kenchan's Avatar
kenchan
humm...wider wheel/tire combo on the rear of a FF platform...
something doesn't chime in. Ive seen narrower wheel/tires on the
rear of a FF sportcompact race car which mades sense.
but i guess this is only for show.
Old May 24, 2004 | 10:14 PM
early_apex
I think you'd only want wider wheels on the front if you had an understeering problem. I think the rear sway takes pretty good care of that on the Mini.
Old Jun 8, 2004 | 10:39 AM
Alex@tirerack's Avatar
Alex@tirerack
I agree, oversteer is not my freind. keep it neutral!
Stay all 4 the same!
Alex
Old Jun 9, 2004 | 08:31 PM
d6-mcs's Avatar
d6-mcs
i am doing 8in in the front and 9 in the rear. here's a pic
Old Jun 9, 2004 | 08:33 PM
d6-mcs's Avatar
d6-mcs
thats not mine but that mini is on 8in front and 9 in rear.
those are 16in, i am doing 17in, 8in wide, with a 30mm offset and a 9in wide, with a 25mm offset.
Colt45Magnus
Sep 7, 2015 10:47 PM
AdrenaliNate
Aug 24, 2015 12:37 PM
Aug 21, 2015 02:29 PM
Aug 21, 2015 11:25 AM
nomar116
Aug 12, 2015 05:24 PM
