Suspension Stud Conversion
Old Nov 26, 2013 | 10:24 AM
dboard7's Avatar
dboard7
Stud Conversion
I have been looking around and find prices from $30 up toalmost $300 for wheel stud conversions. I have a 2010 mini cooper s and waswondering what the difference might be between then and if the ones from ther53 will work in the r56? I found a set at a reasonable price at Detroit tunedby Helix, i know Detroit tuned won’t sell anything that is garbage and Helixhas a great reputation as well! But they are only for the 06 and older willthey work on my r56?
http://www.detroittuned.com/helix-wheel-stud-kit/
Old Nov 26, 2013 | 10:44 AM
Mindspin311's Avatar
Mindspin311
I bought my studs through this company.
Great customer service.
http://www.motorsporthardware.com/wh...ersion-kits-7/
Old Nov 26, 2013 | 10:59 AM
dboard7's Avatar
dboard7
cool ill check them out, thanks!
Old Nov 26, 2013 | 11:14 AM
Mindspin311
Here is a pic of the studs installed
Old Nov 26, 2013 | 11:33 AM
ZippyNH's Avatar
ZippyNH
There is a date split on the r53 because mini switched to a thicker (think 14 mm bolt) from thinner, industry standard bolt/lug ( 12mm I think)....
So the older pre2006 studs will not work...
99% of rims can be used with either hole size/bolts....there is enough wiggle room there....
Old Nov 26, 2013 | 11:42 AM
dboard7's Avatar
dboard7
i just emailed them to see what they recomend i may get spacers too if i can fit a wder tire in there, what size did you get? they recomended the http://www.motorsporthardware.com/75...d-kit-14x1-25/
Old Nov 26, 2013 | 04:41 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You may want to check out our TSW stud kits. these convert the studs to 1.5 thread pitch so getting new nuts is easier and cheaper.
http://www.waymotorworks.com/m14x1.2...-stud-kit.html
We also do a kit that converts to 12mm if you don't have 14mm holes in the wheels
http://www.waymotorworks.com/m14-to-...rsion-kit.html
Old Nov 26, 2013 | 06:31 PM
dboard7's Avatar
dboard7
Thanks Way! Hopefully there will be a black Friday or cyber Monday special on these!? How will they hold up to the abuse of a track car?
Old Nov 27, 2013 | 05:48 AM
v10climber's Avatar
v10climber
We've done hundreds of auto-x runs on the 14 to 12mm conversion studs and have had zero issues.
Old Nov 29, 2013 | 10:21 PM
ra2fanatic's Avatar
ra2fanatic
Originally Posted by v10climber
we've done hundreds of auto-x runs on the 14 to 12mm conversion studs and have had zero issues.
+1
Old Dec 1, 2013 | 05:16 PM
dboard7's Avatar
dboard7
so i think im going to get the tsw ones from way and some 5mm spacers while im at it and realized i had to get special bolts for my wheels from discount tire tuner lugs will the bolts that come with the kit work with my wheels?
Old Dec 1, 2013 | 07:40 PM
WayMotorWorks
Vendor
The Muteki nuts we offer are a tuner style nut to give you more clearance.
http://www.waymotorworks.com/muteki-lug-nuts.html
Old Dec 1, 2013 | 08:10 PM
dboard7's Avatar
dboard7
thanks way! just put the order in hopefully i made it in time to get the free shipping!
NYMADMINI
Dec 14, 2016 02:33 PM
vetsvette
Oct 11, 2015 06:05 PM
Oct 1, 2015 12:13 PM
Sep 29, 2015 12:11 PM
