my brake sensor is on
Old Nov 21, 2013 | 02:53 PM
spr061's Avatar
spr061
I drive a base 2004. I changed my brakes myself about a month ago, I broke the rear brake sensor so I replaced it. I put my new wheels on, I was good to go. I took the new wheels off now that it's winter, and when I got home the yellow brake pad sensor light came on. I know my brakes are new. Mag of Columbus told me it cannot be reset, is there another way, I have checked the sensors they look physically as they did after I installed the anew kit. Thanks
Old Nov 21, 2013 | 08:03 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Is there more than one brake sensor? If there is only one it needs to be replaced even though it looks OK and is only a month old. Is it a MINI part or generic?
see post 4 or contact Way at Way Motor Works
https://www.northamericanmotoring.co...e-sensors.html
Old Nov 21, 2013 | 08:13 PM
cerenkov's Avatar
cerenkov
You can always cut the wires and short them together. You will loose the functionality of the sensor but you won't have the light and it seems like you know how to check your brake pads for wear so that shouldn't be an issue.
Old Nov 22, 2013 | 10:22 AM
BillJackson's Avatar
BillJackson
This means that there are fault codes stored in the parking brake computer. The system has seen a fault so it has activated the message. What you will need to do is have the fault codes read in the system with the proper diagnostic scan tool. Most common problems with the parking brake system is either the switch or the parking brake actuator. Without checking the codes or clearing them with the scan tool then the message will always be there.
Old Nov 22, 2013 | 10:25 AM
Capt_bj's Avatar
Capt_bj
on a GEN1, after you change a worn sensor there IS a reset procedure you must do.
After replacing the sensor, turn the ignition key to the #2 position for around 30 seconds without turning over the engine...the light goes out!
from MINIMANIA
I've used this proceure on cars for foks MANY times . . .
Old Nov 22, 2013 | 06:00 PM
spr061's Avatar
spr061
I've hooked up a scan tool and it didn't pull any codes, I work for Chrysler here in Columbus,
Old Nov 22, 2013 | 06:02 PM
spr061's Avatar
spr061
The front sensor was not replaced. The rear had to be replaced because I messed the old one up. It came from napa
Toolman
Jan 20, 2016 06:50 AM
Aug 25, 2015 09:18 AM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
