Drivetrain Can I use the washer fluid tank for Meth?
Old Nov 17, 2013 | 10:39 PM
MarioKart's Avatar
MarioKart
Vendor
I have had meth in other cars and now considering it in my GP2. Since I have no back seat, and I carry lots of product for work, I don't want to loose hatch space. Has anyone used the windshield the wiper fluid tank? I was looking at it last night when installing my H8 HID's. I have a few questions
1. Where should the pump go, lower than the tank?
2. What kit should I buy?
3. Nozzle size?
4. What psi shiould I have come on? I hit 18psi now after the IC, and DP install.
5. How much fluid does the tank hold?
Mario
Old Nov 18, 2013 | 01:09 AM
scubbysnacks's Avatar
scubbysnacks
Forwarded a pm sent to another member answering similar questions, the install was on my car see SIG below.
Old Nov 19, 2013 | 10:49 AM
ra2fanatic's Avatar
ra2fanatic
You can, but I would not recommend it. I've heard too many bad things about meth kits utilizing the washer fluid tank for meth. Go with proper meth kit, Aquamist HFS-3 or 4. You ponied up for a GP2, don't cheap out on the meth kit now!
Old Nov 19, 2013 | 03:37 PM
InjectedGT's Avatar
InjectedGT
Doesn't sound like he's doing it for money, he's doing it for space. I've heard of quite a few people (non mini though) doing this. What reason is that plastic jug not as worthy as one you buy specifically for meth?
Old Nov 19, 2013 | 03:49 PM
ra2fanatic's Avatar
ra2fanatic
Because the last thing you want when you have a front impact is meth being the first thing spilling out of the engine bay. Odorless and colorless chemical fire is probably the worst fire you can have and highly suggest you don't do it.
Old Nov 19, 2013 | 04:14 PM
scubbysnacks
Well then I'm a dead man walking because I've been doing just that for the last 6 months.
Old Nov 19, 2013 | 04:20 PM
ra2fanatic's Avatar
ra2fanatic
Your call man. I'd rather the tank in the back. Besides, the tank isn't that much bigger to get in the way of losing trunk space. I even carry a case full of tools and don't feel I've lost space. But to each their own you know.
Old Nov 20, 2013 | 12:59 PM
ThumperMCS's Avatar
ThumperMCS
Listen to ra2
Go with an Aquamist HFS-3 or 4....its bar none the best on the market. Tie it to IDC, its more consistent than boost. You can play with nozzle sizes once you install it...I ran a .7mm most of the time
Old Nov 20, 2013 | 01:48 PM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by ThumperMCS
Listen to ra2
Also, what about noise? I work out of my car and on Bluetooth a lot, is the pump pretty quiet? I'm sure I can make it, so it camouflaged. IDC?
Old Nov 20, 2013 | 02:01 PM
ThumperMCS's Avatar
ThumperMCS
Well the pump only activates when you're on it, in which case whoever your talking to on bluetooth is probably going to hear your exhaust more-so than the pump.
It's noticeable, but it's not loud.
IDC is injector duty cycle....and the Aquamists can be triggered from this rather than boost. Gives a much more consistent operation than a kit that is tied to boost only (as the boost levels on the R56 can vary quite a bit).
Hobine
Oct 7, 2015 04:52 PM
silence2-38554
Sep 28, 2015 12:19 PM
rt808
Sep 25, 2015 01:59 PM
